Hello, everyone. I have fresh installment of Discourse in Docker.
So the problem is that after container rebuild, container is up and I can access app page. However, I get 502 as response. In logs or when I try accessing i.e. rails c (inside container) all I can see is this error:
`permission_error’: bootsnap doesn’t have permission to write cache entries in ‘tmp/cache/bootsnap/compile-cache’ (or, less likely, doesn’t have permission to read ‘/usr/local/lib/ruby/2.7.0/set.rb’) (Bootsnap::CompileCache::PermissionError)
In order to fix this I have to chown -R discourse:discourse /var/www/discourse/tmp (to be exact, it’s /var/www/discourse/tmp/cache/bootsnap) directory inside container, and right after app works fine even without restart. It’s quite obnoxious thing to do manually after each rebuild.
I was thinking that I can tackle it using custom commands section in app.yml with mentione above chown -R discourse:discourse /var/www/discourse/tmp, but unfortunately it doesn’t work. Commands seem to be called there (tried mkdir just to check), but file permissions are not affected.
What can be the issue here and how it can be resolved? Maybe there is some way to correctly change file permissions?
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
- "templates/web.ssl.template.yml"
#- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "80:80" # http
- "443:443" # https
params:
#db_shared_buffers: "256MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LC_ALL: en_US.UTF-8
LANG: en_US.UTF-8
LANGUAGE: en_US.UTF-8
#UNICORN_WORKERS: 3
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: 'example.com'
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'test@mail.com'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: smtp.mail.io
#DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: 111
DISCOURSE_SMTP_PASSWORD: 111
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
#DISCOURSE_SMTP_DOMAIN: discourse.example.com # (required by some providers)
#DISCOURSE_NOTIFICATION_EMAIL: noreply@discourse.example.com # (address to send notifications from)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
#LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
## The http or https CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
## The maxmind geolocation IP address key for IP address lookup
## see https://meta.discourse.org/t/-/137387/23 for details
#DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
run:
#- exec: chown -R discourse:discourse /var/www/discourse/tmp/cache/bootsnap # example command on how I'd tried to fix file permissions
You didn’t run discourse-setup, right? It should have defined some things that you have commented out. I just made those changes and want to be sure that it’s working as expected.
Is there a reason you’re not using let’s encrypt?
I don’t see an explanation for your problem, though.
Firstly, application was built using discourse-setup. After few tries of rebuilding it and seeing no positive result, I moved to one of pre-defined .yml configs from /samples directory, and then simply edited out it with my credentials.
Why not Let’s encrypt - asked to use client’s certificates. But as far as I understand - certificates have nothing to do with it, as they’re valid and there is no issue from it.
The issue seems to be on project level, which is specifically related to bootsnap cache file permissions (maybe the issue is on the side of Bootsnap).
Thanks. I agree that’s not likely to be the problem. I did a couple of installs yesterday that worked just fine. I don’t see any explanation for your problem.
Fixed the problem! No restarts were required. The ‘tmp’ directory permissions were assigned to ‘discourse:www-data’ before the owner change. Hope this is something that in the future could be fixed so that this manual action won’t be needed after each rebuild.
The owner user and group of the /var/www/discourse/tmp directory was discourse:www-data after launching the container. Reassigning to discourse:discourse solved the issue. This had not happened to me before and I’ve been using discourse for several months already. Anyway, it was an easy fix and might have been random, so I don’t want to bother you with it anymore. Thanks a lot @gerhard!
