تتعرض إعادة بناء التطبيق للانهيار في كل مرة :(
Hi,
I’m trying to rebuild a discourse that I have to change the port where it connects. It gives always this error when I launch the discourse_setup. Any idea of the reason why?
I, [2018-11-07T10:52:46.331960 #14]  INFO -- : Loading --stdin
I, [2018-11-07T10:52:46.337198 #14]  INFO -- : > locale-gen $LANG && update-locale
I, [2018-11-07T10:52:47.317933 #14]  INFO -- : Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
I, [2018-11-07T10:52:47.318818 #14]  INFO -- : > mkdir -p /shared/postgres_run
I, [2018-11-07T10:52:47.323093 #14]  INFO -- :
I, [2018-11-07T10:52:47.323458 #14]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2018-11-07T10:52:47.327843 #14]  INFO -- :
I, [2018-11-07T10:52:47.328217 #14]  INFO -- : > chmod 775 /shared/postgres_run
I, [2018-11-07T10:52:47.331105 #14]  INFO -- :
I, [2018-11-07T10:52:47.331469 #14]  INFO -- : > rm -fr /var/run/postgresql
I, [2018-11-07T10:52:47.335344 #14]  INFO -- :
I, [2018-11-07T10:52:47.335668 #14]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2018-11-07T10:52:47.338294 #14]  INFO -- :
I, [2018-11-07T10:52:47.338610 #14]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2018/11/07 10:52:47 socat[46] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2018-11-07T10:52:47.359290 #14]  INFO -- :
I, [2018-11-07T10:52:47.359586 #14]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2018-11-07T10:52:47.361873 #14]  INFO -- :
I, [2018-11-07T10:52:47.362154 #14]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2018-11-07T10:52:47.363789 #14]  INFO -- :
I, [2018-11-07T10:52:47.364068 #14]  INFO -- : > mkdir -p /shared/postgres_run/10-main.pg_stat_tmp
I, [2018-11-07T10:52:47.365414 #14]  INFO -- :
I, [2018-11-07T10:52:47.365755 #14]  INFO -- : > chown postgres:postgres /shared/postgres_run/10-main.pg_stat_tmp
I, [2018-11-07T10:52:47.367216 #14]  INFO -- :
I, [2018-11-07T10:52:47.370687 #14]  INFO -- : File > /etc/service/postgres/run  chmod: +x
I, [2018-11-07T10:52:47.373525 #14]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x
I, [2018-11-07T10:52:47.377245 #14]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x
I, [2018-11-07T10:52:47.380420 #14]  INFO -- : File > /root/upgrade_postgres  chmod: +x
I, [2018-11-07T10:52:47.380803 #14]  INFO -- : > chown -R root /var/lib/postgresql/10/main
I, [2018-11-07T10:52:49.615030 #14]  INFO -- :
I, [2018-11-07T10:52:49.615642 #14]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/10/bin/initdb -D /shared/postgres_data || exit 0
I, [2018-11-07T10:52:49.617295 #14]  INFO -- :
I, [2018-11-07T10:52:49.617531 #14]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2018-11-07T10:52:49.671179 #14]  INFO -- :
I, [2018-11-07T10:52:49.671651 #14]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2018-11-07T10:52:49.673376 #14]  INFO -- :
I, [2018-11-07T10:52:49.673775 #14]  INFO -- : > /root/upgrade_postgres
I, [2018-11-07T10:52:49.680547 #14]  INFO -- :
I, [2018-11-07T10:52:49.680823 #14]  INFO -- : > rm /root/upgrade_postgres
I, [2018-11-07T10:52:49.682012 #14]  INFO -- :
I, [2018-11-07T10:52:49.684255 #14]  INFO -- : Replacing data_directory = '/var/lib/postgresql/10/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.684831 #14]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.685703 #14]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.686370 #14]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.687144 #14]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.687794 #14]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.688538 #14]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2018-11-07T10:52:49.693970 #14]  INFO -- :
I, [2018-11-07T10:52:49.694372 #14]  INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = $db_max_wal_senders in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.694814 #14]  INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = $db_wal_level in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.695581 #14]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.696350 #14]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.697122 #14]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/10/main/postgresql.conf
I, [2018-11-07T10:52:49.698374 #14]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/10/main/pg_hba.conf
I, [2018-11-07T10:52:49.698767 #14]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/10/main/pg_hba.conf
I, [2018-11-07T10:52:49.699379 #14]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main
I, [2018-11-07T10:52:49.700335 #14]  INFO -- : > sleep 5
2018-11-07 10:52:49.817 UTC [69] FATAL:  data directory "/shared/postgres_data" has group or world access
2018-11-07 10:52:49.817 UTC [69] DETAIL:  Permissions should be u=rwx (0700).
I, [2018-11-07T10:52:54.703603 #14]  INFO -- :
I, [2018-11-07T10:52:54.704237 #14]  INFO -- : > su postgres -c 'createdb discourse' || true
createdb: could not connect to database template1: could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
I, [2018-11-07T10:52:54.798068 #14]  INFO -- :
I, [2018-11-07T10:52:54.798442 #14]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
psql: could not connect to server: No such file or directory
I, [2018-11-07T10:52:54.858517 #14]  INFO -- :
I, [2018-11-07T10:52:54.858844 #14]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2018-11-07T10:52:54.905524 #14]  INFO -- :
I, [2018-11-07T10:52:54.905887 #14]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2018-11-07T10:52:54.952361 #14]  INFO -- :
I, [2018-11-07T10:52:54.952801 #14]  INFO -- : Terminating async processes
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 95 exit 2>
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
ec6a6e543e5cf2fd213b11eae2ada521cd75849cdfd7eff1b4d171f303756fe1
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Thanks!
Key here is those lines.
You gotta fix the permissions in that folder.
Thank you! The question now is… where?
Since I’m trying to run a docker container… what container is going to be start with the rebuild? Or where do I find that folder? Since in the filesystem I don’t have that path.
That defaults to be inside /var/discourse/shared/standalone/.
You can check actual values in the /var/discourse/containers/app.yml in the section volumes.
If I set the permissions to 0700 I get:
2018-11-07 11:31:56.728 GMT [69] LOG:  skipping missing configuration file "/shared/postgres_data/postgresql.auto.conf"
2018-11-07 11:31:56.730 UTC [69] FATAL:  could not read permissions of directory "/shared/postgres_data": Permission denied
:frowning: ideas?
I think you changed the owner of the folder too. Why did you make such changes? Was something broken?
It worked when I put the recursive flag to chmod :slight_smile: thank you.
