E-mail-setup opstarten: is een subdomein nodig?
Hi there! I’m a complete novice at sysadmin stuff. I had a question about the following quote from the Bootstrapping tutorial:
Please note that in any email provider, you must verify and use the subdomain, e.g. discourse.example.com . If you verify the domain only, e.g. example.com , mail will not be configured correctly.
Does this apply even if, in Digitalocean, you’re using a domain (example.com) for your droplet, and not a subdomain? Thank you
A subdomain isn’t necessary as long as your mail domain and Discourse domain are the same.
E.g. if you’re hosting Discourse on example.com and your mail server sends from noreply@example.com there shouldn’t be any issue.
