フラグの「claim」機能を復活させてください
Hello!
Is it possible to get the “claim” feature back when dealing with flags? On our Discourse site, where we often get more than 10 flags a day, and have a team of moderators working on them, it was perfect to show which mod is working on what.
I know that there’s the “assign” feature for an individual thread, but you cannot see who has been assigned to a thread from the flagged menu.
Thank you kindly.
「いいね!」 3
I believe this still exists @eviltrout?
「いいね!」 2
I honestly haven’t tested it with the new reviewable branch so I suspect it has regressed. I’ll check it out soon.
「いいね!」 5
Thank you! I can confirm that it’s not an option anymore, and I can provide screenshots if necessary.
Would you be able to tell me if this feature may come back? This way I know whether to find an alternative, or to just wait a bit.
It’s definitely going to come back. With any luck I’ll have something tomorrow, but it depends what else comes up in the meantime.
「いいね!」 9
Excellent!! Thank you so much! :smile:
Okay as promised, I’ve re-implemented claiming in core Discourse. I’d love for you to try it out and provide feedback:
You can turn it on with the site setting reviewable claiming. You can set it to disabled / optional / required.
「いいね!」 6
Thank you thank you thank you! Will be back asap with feedback!
「いいね!」 2
Thanks, as usual with new features like this there might be some bugs / awkward things. We’ll try to fix it quickly.
「いいね!」 7
