At the bottom of a page served from discourse.org when viewing posts.
This link directs me to an error page:
https://meta.discourse.org/t/flagged-post-removed-by-staff/318881/{basePath}/u/{username}/messages
This has been fixed in
Fantastic. Must’ve been overlooked when it was first written/last updated. ![]()
This only fixed the English version. Since translations were not updated afterwards, the recent release does not contain the fix for other languages. Those probably receive the fix only later today. Will they be added to stable?
Yes, strings on stable will be available on crowdin, and updates pulled into the stable branch ![]()
Does that mean I will have to do that translation a second time for stable? ![]()
(As translation memory did not suggest the prior translation, it is a lot of work compared to search and replace a character).
At the moment, since all the strings are identical, translations made to the ‘main’ section will apply to both ‘main’ and ‘stable’. So in this case, you don’t need to make the translation twice. Just make it for the ‘main’ string, and it’ll be pulled into stable as well.
As main starts to change strings, and introduce new ones, a separate section for ‘stable only’ strings will appear in crowdin.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
