画像閲覧機能はありますか?
Is there a way to browse all the images that have been uploaded to a Discourse installation? I was looking for something I had seen before, and didn’t have a practical way of finding it in the haystack of old posts.
There is not. You would need a plugin to do that.
「いいね!」 2
I suspected as much, since a search didn’t turn up anything. Thanks!
Depending on what you mean by “Browse” you could also get a list of the uploads with the data explorer plugin.
「いいね!」 2
