Why doesn’t this code:
var www_server = Sealious.ChipManager.get_chip("channel", "www_server");
www_server.route({
method: "GET",
path: "/users.csv",
handler: function(context, request){
// .. logic goes here
preserve newlines? Did the syntax change or is there something I am missing?
1 лайк
gkln
10.Август.2016 10:58:19
You should encapsulate the code block with ``` instead of `.
www_server.route({
method: "GET",
path: "/users.csv",
2 лайка
Please take a look at the source of my message: I am using ```…
cpradio
(cpradio)
10.Август.2016 11:35:00
4
It seems to be the extra space after the closing ```
3 лайка
I see, removing the redundant space does fix the issue.
But It’s not CommonMark compliant, right? When I pasted the code [here] it behaved as it should.
1 лайк
cpradio
(cpradio)
10.Август.2016 13:12:26
6
Discourse isn’t using CommonMark yet (to my knowledge) so if it works at commonmark.js demo , when Discourse switches to CommonMark, it should resolve itself.
2 лайка
eviltrout
(Robin Ward)
10.Август.2016 14:45:48
7
Yes I can confirm we’re note on CommonMark yet. In 1.6 I did a lot of work to convert our existing markdown to ES6 so that we could try plugging in a different engine and see how well it works.
5 лайков
sam
(Sam Saffron)
26.Июнь.2017 14:04:12
8
Rebaked OP and all seems fine
trailing spaces
no
longer
break this
Per our migration plans , I just enabled markdown.it at Meta.
It is an excellent CommonMark compliant engine. I expect quite a few edges to be found during this period of testing.
Do not open bugs about the new Engine, just reply here.
I/we will be updating the top post here with the list of issues and striking out stuff as it is fixed.
Current known issues (to be fixed)
Onebox vanishes after you start typing and works not-super consistently
pending…
3 лайка
