In the thread titled ‘Bugs in DiscourseHub for Android?’, ManuelS reports two issues after the dark mode update: (1) the /e/OS Discourse instance (https://community.e.foundation/) fails to display unread/new item counts, regardless of list position; and (2) the settings cog wheel icon is unresponsive. ManuelS confirms the issue is instance-specific, not positional, and persists after reconnecting. pmusaraj asks for Android version details and confirms the cog issue doesn’t occur on Android 13. ManuelS notes using /e/OS 2.2 (Android 13) and dark mode, and shares a screenshot showing the missing counts. pmusaraj confirms the /e/OS issue stems from its older Discourse version (March 2024), which lacks a required API; updating the instance should resolve it. Moin reports the cog issue also occurs on Android 14. Further investigation by Moin reveals the bug is language-dependent — the cog works in English but not German (tested on Galaxy Tab S9 FE, One UI 6.1). pmusaraj confirms the language-based repro and releases a fix in version 2.0.3, which ManuelS verifies as working. The /e/OS issue remains pending their server update. Tags: discourse-hub, fixed.
since the version introducing dark mode in DiscourseHub for Android I experience two problems:
The first entry in the list of Discourse forums (/e/OS community) does not show new or unread items anymore. The line is missing completely although there are new and unread items as I can see when I touch the entry to open the forum. For all following forums the line is showing and the numbers are correct.
The cog wheel icon on the upper right does not work anymore. There is no reaction on touches.
Anyone else experiencing theses problems?
And probably someone has found solutions for them?
I digged a little deeper and found out that the first issue isn’t related to the position in the list but to the Discourse instance (https://community.e.foundation/). Even after deleting and readding it at the end of the list the problem still exists for this forum while the new first entry continues to show new and unread items.
Might there be some instance settings required to enabled fetching and showing of these numbers?
Yes, definitely I did so.
I also repeated the whole procedure of deleting, readding and connecting without any change.
My current /e/OS version is 2.2 based on Android 13. The problem was definitely already there in version 2.1 but I cannot say whether it started when installing that version.
My feeling was that it started with DiscourseHub 2.0.0.
What I have forgotten to note is that I use dark mode (which I can’t change anymore because of the not working cog wheel button).
This is what it looks like. 12 new items in the Fairphone Community Forum is correct, for the /e/OS community currently 1 unread and 20 new items would be correct.
@ManuelS I can confirm the /e/OS community issue. It’s because that instance is running on a slightly older version of Discourse, from March 2024. It’s not that old, but in the latest release of the mobile app, we made a change that targets an API that we added to core after March 2024. I will see how hard it is to restore the old code, but in any case, an update of Discourse on the /e/OS side should fix the missing numbers.
Will try to reproduce the cog button issue on a different Android version. We don’t test with /e/OS, but this is likely an issue with other Android flavors too.
Hmm, I believe you, but so far I haven’t been able to reproduce this. Tried multiple devices, multiple emulators, pinged a colleague as well, no repro. Can you share more info about your device (Android version, flavour, etc.)? Thanks!
