Modifica in blocco impostazioni: attivare soluzione accettata per più sottocategorie
I have a category with a number of subcategories. I would like to enable the Allow topic owner and staff to mark a reply as the solution for all the subcategories. Right now to do it through the UI is one at a time and involves a lot of clicking back and forth. Is there a better way to do this in bulk?
You could use the API per:
But, to be honest, by the time you finish writing the script you would probably finish with all your clicking.
