The buttons to replace or append tags appear in the topic list bulk actions modal even when tagging is not enabled. Clicking on either provides a text field to type tags, which says “Loading failed” as the autocomplete option. A 404 error is thrown by the attempted tag search https://discourse.example.com/tags/filter/search?q=&limit=5&selected_tags=&filterForInput=true
Can we still repro this @simon?
Yes, the Replace Tags and Append Tags options are still given when tags are disabled. If you try to enter a tag name, an error modal pops up saying ‘The requested URL or resource could not be found.’
Is this a good starter task @sam?
Yes this feels like an easy change to me, client knows if tagging is enabled or not.
Hello guys,
This is a pretty long standing bug and I decided to give it a try. I just submitted this pull request.
Before:
After:
Thanks, fix is merged!
