مرحبًا،
أجريت ترقية من الإصدار 2.8.14 إلى الإصدار 3.0.0، باستخدام هذه العملية:
docker exec -it app rails runner "Discourse.enable_readonly_mode(Discourse::USER_READONLY_MODE_KEY)"
cd /var/discourse
git pull
./launcher rebuild app --docker-args --net=host --skip-mac-address
docker exec -it app rails runner "Discourse.disable_readonly_mode(Discourse::USER_READONLY_MODE_KEY)"
في المراحل الأولى من الترقية، ظهر لي خطأ في bundler كالتالي:
remote: Enumerating objects: 18, done.
remote: Counting objects: 100% (18/18), done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 18 (delta 10), reused 17 (delta 10), pack-reused 0
Unpacking objects: 100% (18/18), 5.00 KiB | 512.00 KiB/s, done.
From https://github.com/discourse/discourse_docker
e6cb71c..1de36f6 main -> origin/main
+ 2e142d4...8ca4f38 ruby-3.2 -> origin/ruby-3.2 (forced update)
Updating e6cb71c..1de36f6
Fast-forward
image/discourse_dev/Dockerfile | 2 ++
1 file changed, 2 insertions(+)
x86_64 arch detected.
2.0.20220818-0047: Pulling from discourse/base
Digest: sha256:7734701087766821ffb2ddcef423754798bd345c2ac0d550131c6e6905c268e8
Status: Image is up to date for discourse/base:2.0.20220818-0047
docker.io/discourse/base:2.0.20220818-0047
WARNING: containers/app.yml file is world-readable. You can secure this file by running: chmod o-rwx containers/app.yml
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
/usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-01-11T22:11:31.990663 #1] INFO -- : Reading from stdin
I, [2023-01-11T22:11:32.008485 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2023-01-11T22:11:32.014899 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2023-01-11T22:11:32.021283 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2023-01-11T22:11:32.023029 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2023-01-11T22:11:32.023985 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2023-01-11T22:11:32.024780 #1] INFO -- :
I, [2023-01-11T22:11:32.030179 #1] INFO -- :
I, [2023-01-11T22:11:32.030827 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-01-11T22:11:32.031567 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2023-01-11T22:11:32.032543 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-01-11T22:11:32.033375 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-01-11T22:11:32.034068 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-01-11T22:11:32.034790 #1] INFO -- :
I, [2023-01-11T22:11:32.038297 #1] INFO -- : redis installed
I, [2023-01-11T22:11:32.038759 #1] INFO -- :
I, [2023-01-11T22:11:32.044082 #1] INFO -- : logfile ""
I, [2023-01-11T22:11:32.044505 #1] INFO -- :
I, [2023-01-11T22:11:32.046813 #1] INFO -- :
I, [2023-01-11T22:11:32.050045 #1] INFO -- :
I, [2023-01-11T22:11:32.050510 #1] INFO -- :
I, [2023-01-11T22:11:32.055661 #1] INFO -- : thpoff is installed!
I, [2023-01-11T22:11:32.056251 #1] INFO -- :
I, [2023-01-11T22:11:42.170880 #1] INFO -- :
I, [2023-01-11T22:11:42.171305 #1] INFO -- :
I, [2023-01-11T22:11:42.291228 #1] INFO -- :
I, [2023-01-11T22:11:42.291649 #1] INFO -- :
I, [2023-01-11T22:11:42.408939 #1] INFO -- :
I, [2023-01-11T22:11:42.409402 #1] INFO -- :
I, [2023-01-11T22:11:42.413262 #1] INFO -- :
I, [2023-01-11T22:11:42.417373 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2023-01-11T22:11:42.423865 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2023-01-11T22:11:42.430470 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2023-01-11T22:11:42.436838 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2023-01-11T22:11:42.443359 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2023-01-11T22:11:42.449717 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2023-01-11T22:11:42.450156 #1] INFO -- :
I, [2023-01-11T22:11:42.453602 #1] INFO -- :
46:C 11 Jan 2023 22:11:42.462 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
46:C 11 Jan 2023 22:11:42.462 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=46, just started
46:C 11 Jan 2023 22:11:42.462 # Configuration loaded
46:M 11 Jan 2023 22:11:42.463 * monotonic clock: POSIX clock_gettime
46:M 11 Jan 2023 22:11:42.464 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
46:M 11 Jan 2023 22:11:42.464 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (31436/31436), done.
I, [2023-01-11T22:11:46.521814 #1] INFO -- : HEAD is now at 44c53cb3 DEV: Update internal `package.json` metadata (#17978)
I, [2023-01-11T22:11:46.522342 #1] INFO -- :
I, [2023-01-11T22:11:46.687168 #1] INFO -- :
I, [2023-01-11T22:11:46.687649 #1] INFO -- :
I, [2023-01-11T22:11:46.693562 #1] INFO -- :
I, [2023-01-11T22:11:46.694073 #1] INFO -- :
I, [2023-01-11T22:11:46.700456 #1] INFO -- :
I, [2023-01-11T22:11:46.700906 #1] INFO -- :
I, [2023-01-11T22:11:51.425872 #1] INFO -- :
I, [2023-01-11T22:11:51.426067 #1] INFO -- :
I, [2023-01-11T22:11:52.937277 #1] INFO -- : Branch 'stable' set up to track remote branch 'stable' from 'origin'.
I, [2023-01-11T22:11:52.937763 #1] INFO -- :
I, [2023-01-11T22:11:52.942993 #1] INFO -- :
I, [2023-01-11T22:11:52.943124 #1] INFO -- :
I, [2023-01-11T22:11:52.947751 #1] INFO -- :
I, [2023-01-11T22:11:52.948175 #1] INFO -- :
I, [2023-01-11T22:11:52.952909 #1] INFO -- :
I, [2023-01-11T22:11:52.953419 #1] INFO -- :
I, [2023-01-11T22:11:52.958174 #1] INFO -- :
I, [2023-01-11T22:11:52.958683 #1] INFO -- :
I, [2023-01-11T22:11:52.962908 #1] INFO -- :
I, [2023-01-11T22:11:52.963002 #1] INFO -- :
I, [2023-01-11T22:11:52.967906 #1] INFO -- :
I, [2023-01-11T22:11:52.968059 #1] INFO -- :
I, [2023-01-11T22:11:52.974492 #1] INFO -- :
I, [2023-01-11T22:11:52.974636 #1] INFO -- :
I, [2023-01-11T22:11:52.981277 #1] INFO -- :
I, [2023-01-11T22:11:52.981426 #1] INFO -- :
I, [2023-01-11T22:11:52.988544 #1] INFO -- :
I, [2023-01-11T22:11:52.988650 #1] INFO -- :
I, [2023-01-11T22:11:52.995236 #1] INFO -- :
I, [2023-01-11T22:11:52.995665 #1] INFO -- :
I, [2023-01-11T22:11:53.002123 #1] INFO -- :
I, [2023-01-11T22:11:53.002620 #1] INFO -- :
I, [2023-01-11T22:11:53.008952 #1] INFO -- :
I, [2023-01-11T22:11:53.009509 #1] INFO -- :
I, [2023-01-11T22:11:53.023178 #1] INFO -- :
I, [2023-01-11T22:11:53.023305 #1] INFO -- :
I, [2023-01-11T22:11:53.028782 #1] INFO -- :
I, [2023-01-11T22:11:53.029010 #1] INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2023-01-11T22:11:53.029663 #1] INFO -- :
I, [2023-01-11T22:11:55.157643 #1] INFO -- :
I, [2023-01-11T22:11:55.157770 #1] INFO -- :
I, [2023-01-11T22:11:56.384108 #1] INFO -- :
I, [2023-01-11T22:11:56.384233 #1] INFO -- :
I, [2023-01-11T22:11:57.450187 #1] INFO -- :
I, [2023-01-11T22:11:57.450656 #1] INFO -- :
I, [2023-01-11T22:11:57.455146 #1] INFO -- :
I, [2023-01-11T22:11:57.455633 #1] INFO -- :
I, [2023-01-11T22:11:57.458991 #1] INFO -- :
I, [2023-01-11T22:11:57.459528 #1] INFO -- :
I, [2023-01-11T22:11:57.463224 #1] INFO -- :
I, [2023-01-11T22:11:57.464140 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2023-01-11T22:11:57.464741 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2023-01-11T22:11:57.465363 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-11T22:11:57.465927 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-11T22:11:57.466452 #1] INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2023-01-11T22:11:57.466894 #1] INFO -- :
I, [2023-01-11T22:11:57.469846 #1] INFO -- : done configuring web
I, [2023-01-11T22:11:57.470392 #1] INFO -- :
I, [2023-01-11T22:11:58.205287 #1] INFO -- : Successfully installed bundler-2.4.1
1 gem installed
I, [2023-01-11T22:11:58.205417 #1] INFO -- :
I, [2023-01-11T22:12:04.207590 #1] INFO -- :
I, [2023-01-11T22:12:04.208261 #1] INFO -- :
warning " > @mixer/parallel-prettier@2.0.3" has unmet peer dependency "prettier@^2.0.0".
warning "eslint-config-discourse > eslint-plugin-lodash@7.1.0" has unmet peer dependency "lodash@>=4".
I, [2023-01-11T22:13:13.024109 #1] INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts/discourse $(node -e 'if(JSON.parse(process.env.npm_config_argv).original.includes(`--frozen-lockfile`)){console.log(`--frozen-lockfile`)}')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
Done in 38.23s.
Done in 61.96s.
yarn cache v1.22.19
success Cleared cache.
Done in 6.12s.
I, [2023-01-11T22:13:13.029790 #1] INFO -- :
I, [2023-01-11T22:13:13.046717 #1] INFO -- :
I, [2023-01-11T22:13:13.047508 #1] INFO -- :
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
Bundler::PathError: The path `/var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/web-push-369df8f475a4` does not exist.
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/source/path.rb:209:in `load_spec_files'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/source/git.rb:205:in `load_spec_files'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/source/path.rb:107:in `local_specs'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/source/git.rb:172:in `specs'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/lazy_specification.rb:86:in `materialize_for_installation'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:195:in `map!'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:195:in `specs_for_dependency'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:33:in `block in for'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:22:in `loop'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:22:in `for'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:79:in `materialize'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/definition.rb:198:in `missing_specs'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/definition.rb:202:in `missing_specs?'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/installer.rb:253:in `resolve_if_needed'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/installer.rb:82:in `block in run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:12:in `block in lock'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:9:in `open'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:9:in `lock'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/installer.rb:71:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/installer.rb:23:in `install'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/cli/install.rb:62:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/cli.rb:260:in `block in install'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/settings.rb:131:in `temporary'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/cli.rb:259:in `install'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/cli.rb:34:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/cli.rb:28:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/exe/bundle:45:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.4.1/exe/bundle:33:in `<top (required)>'
I, [2023-01-11T22:14:09.288884 #1] INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.4.1
Frozen, using resolution from the lockfile
The definition is missing dependencies, failed to resolve & materialize locally (https://github.com/xfalcox/web-push (at openssl-3-compat@369df8f) is not yet checked out. Run `bundle install` first.)
HTTP GET https://index.rubygems.org/versions
HTTP 206 Partial Content https://index.rubygems.org/versions
HTTP 200 OK https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Looking up gems ["actionmailer", "actionpack", "actionview", "actionview_precompiler", "active_model_serializers", "activejob", "activemodel", "activerecord", "activesupport", "addressable", "annotate", "ast", "aws-eventstream", "aws-partitions", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "aws-sigv4", "better_errors", "binding_of_caller", "bootsnap", "builder", "bullet", "byebug", "capybara", "cbor", "certified", "cgi", "chunky_png", "coderay", "colored2", "concurrent-ruby", "connection_pool", "cose", "cppjieba_rb", "crack", "crass", "css_parser", "debug_inspector", "diff-lcs", "diffy", "digest", "discourse-fonts", "discourse-seed-fu", "discourse_dev_assets", "docile", "ecma-re-validator", "email_reply_trimmer", "erubi", "excon", "execjs", "exifr", "fabrication", "faker", "fakeweb", "faraday", "faraday-net_http", "faraday-retry", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "globalid", "guess_html_encoding", "hana", "hashdiff", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "i18n", "image_optim", "image_size", "in_threads", "jmespath", "json", "json-schema", "json_schemer", "jwt", "kgio", "libv8-node", "listen", "literate_randomizer", "lograge", "logstash-event", "logstash-logger", "logster", "loofah", "lru_redux", "lz4-ruby", "matrix", "maxminddb", "memory_profiler", "message_bus", "method_source", "mini_mime", "mini_portile2", "mini_racer", "mini_scheduler", "mini_sql", "mini_suffix", "minitest", "mocha", "msgpack", "multi_json", "multi_xml", "mustache", "net-http", "net-imap", "net-pop", "net-protocol", "net-smtp", "nio4r", "nokogiri", "oauth", "oauth-tty", "oauth2", "oj", "omniauth", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-oauth2", "omniauth-twitter", "openssl", "openssl-signature_algorithm", "optimist", "parallel", "parallel_tests", "parser", "pg", "prettier_print", "progress", "pry", "pry-byebug", "pry-rails", "public_suffix", "puma", "r2", "racc", "rack", "rack-mini-profiler", "rack-protection", "rack-test", "rails-dom-testing", "rails-html-sanitizer", "rails_failover", "rails_multisite", "railties", "rainbow", "raindrops", "rake", "rb-fsevent", "rb-inotify", "rbtrace", "rchardet", "redis", "redis-namespace", "regexp_parser", "request_store", "rexml", "rinku", "rotp", "rqrcode", "rqrcode_core", "rspec", "rspec-core", "rspec-expectations", "rspec-html-matchers", "rspec-mocks", "rspec-rails", "rspec-support", "rss", "rswag-specs", "rubocop", "rubocop-ast", "rubocop-discourse", "rubocop-rspec", "ruby-prof", "ruby-progressbar", "ruby-readability", "ruby2_keywords", "rubyzip", "sanitize", "sassc", "sassc-rails", "selenium-webdriver", "shoulda-matchers", "sidekiq", "simplecov", "simplecov-html", "simplecov_json_formatter", "snaky_hash", "sprockets", "sprockets-rails", "sshkey", "stackprof", "syntax_tree", "syntax_tree-disable_ternary", "test-prof", "thor", "tilt", "timeout", "tzinfo", "uglifier", "unf", "unf_ext", "unicode-display_width", "unicorn", "uniform_notifier", "uri", "uri_template", "version_gem", "webdrivers", "webmock", "webrick", "websocket", "xorcist", "xpath", "yaml-lint", "zeitwerk"]
HTTP GET https://index.rubygems.org/info/actionmailer
HTTP GET https://index.rubygems.org/info/actionpack
على الرغم من ذلك، استمرت العملية حتى نهاية الترقية، مع تطبيق جميع ترحيلات قاعدة البيانات بنجاح، وتمكنت من تسجيل الدخول إلى مثيل Discourse الخاص بي ورؤية أن الإصدار 3.0.0 قد عُرض. لم أستطع تحديد أي شذوذ بصريًا، وهو ما فاجأني بالنظر إلى خطأ التبعية.
لقد قمت بالعودة إلى التغيير السابق في الوقت الحالي، لأنني أود الحصول على توضيح حول ما إذا كان هذا الخطأ معروفًا/متوقعًا/مفاجئًا لكنه لا يستدعي القلق؟
لم ألتقط جميع مخرجات الترقية، لكن الباقي الذي رأيته بدا «طبيعيًا» بعد إجراء العديد من الترقيات المماثلة في الماضي. لدي سجل خطوات ترحيل قاعدة البيانات محفوظ إذا أردت رؤيتها، لكن كما ذكرت، تم تطبيقها بنجاح.
شكرًا لك!
