Hello dear Discourse friends,
after the latest update all of my calendar events look weird:
Does anybody experience the same or knows why this is happening? On all of our events the date is not displayed correctly.
Any hint is appreciated.
Yes @magie sorry it’s a recent regression. I don’t think most people see it as it might be related to a specific config of your event.
Can you give me the raw of this post please so we can try to reproduce locally and fix it.
Hi @j.jaffeux
Thank you for your quick reply. I am not sure if this is what you mean with raw:
[event start="2025-10-14 09:00" status="private" name="9:00 - 17:00 Uhr: Erste-Hilfe-Kurs · 119 (ABC)" timezone="Europe/Berlin" minimal="true"]
[/event]
Please let me know if something else is meant with “raw”.
It used to look fine before. If we need to change something it would be lovely if you can let us know. (Usually, we also don’t need a timezone since we are always in Berlin timezone.)
That’s what we needed thanks, we will get back to you
We see the same error:
[event start="2025-06-25 17:00" status="public" name="Test Event" timezone="Europe/Berlin" recurrence="every_four_weeks" end="2025-06-25 19:00" allowedGroups="trust_level_0"]
[/event]
displays as:
[date=2025-06-25 time=17:00 format=‚ddd, MMM D LT‘ timezone=Europe/Berlin hideTimezone=false range=from] → Heute 19:00
Thank you
We haven’t been able to repro this locally, but clearly this is related to german and typographic quotes.
Im attempting this fix:
Please let me know if it improves the situation for you.
Yes , the date of the event is displayed correctly again: [quote=“xxx, post:1, topic:17970”]
→ Sat, Jun 28 12:00 PM→Sat, Jun 28 4:00 PM
[/quote]
Thank you very much for the quick fix!!!
Can you also say when the attendant list will be reset again after the event?
Our lists accumulate and accumulate if we do not set the event to private in between to wipe the list. Is there a special configuration to get this?
Thank you …
Thank you @j.jaffeux for the update!
It does work, however, there is still a part not displayed correctly. I think it is when an event spans multiple days:
Raw:
[event start="2025-07-03 09:00" status="private" name="9:00 - 17:00 Uhr: Training: Deeskalations- und foobar" url="https://foobar" timezone="Europe/Berlin" minimal="true" end="2025-07-04 17:00"]
[/event]
No plan yet, but yes I agree it’s not ideal atm.
Thanks, @Magie for catching the similar issue for the ending date.
As @j.jaffeux said, it has to do with quotes localization. Now, both, start and end date should be rendered fine.
The fix applied can be found here:
Fantastic!! Thank you @j.jaffeux and @yuriy
Your updates solved the issue. Many thanks!
Glad to hear it, thanks for the report!
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
