Posso mudar o Lets Encrypt para EssentialSSL / Wildcard SSL?
Can I change this?
During the installation I chose to create ssl using lets encrypt.
Can I change it because I bought EssentialSSL ?
How to do it?
There is this topic Advanced Setup Only: Allowing SSL / HTTPS for your Discourse Docker setup. Note that it’s much harder to configure, requires updating the certificate every time it expires and has no advantages.
3 curtidas
You can, but there’s little good reason to want to.
Let’s encrypt will give you perpetual SSL with zero maintenance.
What possible advantage is there over that?
4 curtidas
