So installieren Sie ein SSL-Zertifikat in Discourse
Hello!
First, sorry my bad english ^^
I purchased a Comodo SSL Certificate for my domain in Dreamhost, but my Discourse forum is in DigitalOcean. How I can add that SSL Certificate?
Thanks! :smile:
Please see Allow SSL / HTTPS for your Discourse Docker setup. However, we strongly recommend using Let’s Encrypt instead. It’s free, auto-renews, and works without extra configuration. See Set up HTTPS support with Let's Encrypt for full details.
Ok, I’ll read what you say, it seems complicated for me.
Thanks!
It is, that’s why we have it listed as “Advanced Setup Only” and recommend Let’s Encrypt.
If you did a standard install, just run discourse-setup again. If you did a one-click install, you’ll need to
cd /var/discourse
./discourse-setup
That’ll pretty much get you a standard install then.
