Hello!
I need to install SSL on my website.
Hosted on: Digital Ocean one click discourse installation.
SSL: From Comodo
If anyone can help me, Please let me know with your charge.
Thanks.
Hello!
SSL: From Comodo
Thanks.
I’ll do it for $100.
Hello @pfaffman
Thanks for the reply. I saw that you are only dealing with letsencrypt. Let’s encrypt needs to be renewed for each 90 days! So, I may need to hire you for each 90 days, which is not affordable to me.
If you can install my Comodo Essential DV SSL, please let me know. or tell me is there any way to auto-renew letsencrypt certificate from the server side.
Thanks!
Let’s encrypt auto-renews, it is part of the setup.
Thanks @jeff
I’m new to these things:slight_smile:
Like @codinghorror said, Let’s Encrypt should auto-renew. If it fails for some reason, even one beyond my control, I’ll fix it.
If you use your Comodo cert, it will have to be re-done every time the cert expires (which is typically once a year), so even if it’s done right it’ll need to be done again.
If you prefer to use your own cert for some reason, I can install that instead, though the charge will be more. You can send me a PM here, or if you can’t, you can contact me via my email address or a contact form on my site.
Already placed the order and send you the confirmation email via your contact form with root access credentials. Let’s proceed with let’s encrypt then.
Thanks.
And it should be up and running encrypted in less than 15 minutes. Thanks very much!
Thanks jay!
After installation, I hope you will configure the proper redirection from non secure http to https
Thanks!
I just sent an email about that too. There is a site setting force https, which you should enable. Just search for “force https” on the settings page and click that. You’ll be all set.
Thank you so much. You are super quick and very professional.
Have a nice day!
