האם אפשר להסתיר את הבלוקים האלה באמצעות הגדרת פלאגין?
Hello! I am planning to install this plugin. Is there an option in the plugin settings to hide the top blocks of categories or is this solved through CSS?
The top block comes from the Discourse Docs Card Filter Customization > Theme component. You can use the plugin without the theme component
