Can I highlight some text in a fenced code block?
סיכום מבוסס בינה מלאכותית
In a discussion about highlighting text in a fenced code block, Kristen expressed the need for a feature to visually distinguish changes in code, suggesting background color or colored text tags. rumpelsepp proposed using diff formatting to achieve this, providing an example. StanD requested clarification on how to apply this formatting in the editor. codinghorror provided a simplified example of diff formatting, illustrating how to denote added and removed lines with + and - symbols, respectively.
In a Discourse forum for techies discussing code in a specific language I’d like to be able to highlight something in a code block. For example the O/P posts some, broken, code and I fix it up. The user has to carefully read my improved code to see what I have changed, and putting a comment in the code like:
xxx = yyy <— I MADE A CHANGE HERE
is a bit lame!, particularly on a complex line.
I suppose, ideally, it would just be a background colour to highlight a section, but if it was possible to put some sort of [color=red] or similar tags into the code that would provide more facilities to people which more artistically then me!
What about diff?
diff --git a/pynote/formatting.py b/pynote/formatting.py
index f0d7d53..eda1906 100644
--- a/pynote/formatting.py
+++ b/pynote/formatting.py
@@ -1,5 +1,5 @@
 import click
-from pynote import config
+from . import config
 def echo(text, no_pager=False):
This is something I am looking for but can you tell me how you did this? That is, how do you format in the editor to get this to display?
line 1
line 2
+line 3
-line 4
line 5
``` diff
line 1
line 2
+line 3
-line 4
line 5
