The discussion revolves around displaying code changes and comments within Discourse Forum discussions. pgr initiated the conversation, looking for a feature to highlight lines, comment, and show edits to code. david suggested using diffs with syntax like + and - to highlight changes.
pgr inquired about combining diffs with language-specific syntax highlighting, which david said is not currently possible due to limitations in the highlight.js library used by Discourse. However, pgr found a potential workaround involving implementing the diff functionality outside the highlighter.
david mentioned that it’s possible to achieve this using a theme component, but it wouldn’t be easy. Anatolia asked how to create colored diffs, and david provided the necessary syntax.
pgr concluded that while the diff construct is helpful, it would be ideal to integrate diff functionality directly into the syntax highlighter. Mittineague suggested an alternative using HTML <del> and <ins> tags to indicate deleted and inserted text.
Not just showing a bit of code with language-specific syntax highlighting (we already have this by introducing it with ```php, for example, and closing with ```).
What I want is to be able to highlight some line, perhaps comment it, and show an edit to the line. These are typically useful in any Forums discussing technical stuff where you advise changes to apply or point out, problematic areas.
Although we do use GitHub for our project, I’m not specifically asking to show changes as they happen in GitHub, but rather something that can be input independently within Discourse - the above image is meant only as an example of how it could look.
Unfortunately not - I agree it would be nice though. We use highlight.js for our syntax highlighting. It looks like there was a similar discussion on their github repo, but they decided it was out of scope for the project.
So they have that gist snippet there, what they’re suggesting is that people implement that outside the highlighter (in that case, it’s marked.js, I guess the same could be done with highlight.js).
Do you think Discourse could do that? Or, previous question, does this make sense in terms of architecture?
I guess the general idea is just to do some find-and-replace, remove the diff marks, send it to the syntax highlighter, and then work on it with some more find-and-replace afterwards. It sounds very awkward but the truth is that the snippet isn’t that complicated at all.
It’s certainly possible, but I don’t think it will be easy. All the syntax highlighting happens in javascript, so it could be manipulated using a theme component.
I will be using the diff construct from now on, it’s helpful.
I don’t see Discourse implementing that other suggestion from the Gist, the more I think of this, the more I believe it would fit perfectly inside the syntax highlighter, not outside.
Basically, as years go by it makes sense to add some features to syntax highlighters, and the basic job of showing code in an easy to read way extends naturally to show also some of the code’s dynamics.
What changed, where, by whom; what am I pointing at; which helpful comment explains the relation of the code to the place where it is being posted, etc.
Thanks to everybody for their participation in this discussion.
