קוד Inline קשה לזיהוי
Inline code code → Normal Code
I’ve found this two solutions, both doesn’t works, I’m missing something or something changed in the meantime.
thx in advanced…
Regards.,
there are 4 settings in admin > settings that you would need to look at
I hope that helps
I can’t see any diferences:
Default code language → auto
autohlighted languages → a list
show copy button to codeblock → activated
autohighted all code → activated
option not available code-fences.
I can’t install code-fences because is a business plan.
NOTE
I also adding plain-text to the list…
Regards.,
As OP mentioned, inline code can be highlighted. The method still works:
  1. Go to https://example.com/admin/customize/themes/1/common/scss/edit (regarding your theme URL may differ)
  2. Go to the bottom of the CSS section and paste the code below:
p>code, li>code {
   color: #c7254e;
   background: #f9f2f4;
   padding: 2px 4px;
   border-radius: 2px;
Save. Done. Your inline text looks like this: изображение
this is for code blocks only (picture below). The original question was about inline text
thx for response I’ve tested your code before but I don’t know why doesn’t works in mi site:
Captura de pantalla de 2021-11-10 13-04-12
Regards.,
Probably your theme is customized already and does not support this.
I use default theme (sorry for non-english text):
I’ve used the default color schema → light
Regards.,
I’ve just had a test on my site with Default Light theme, and it works for me. :+1: I had to refresh my page for it to display properly.
Did you add it as a new theme component? If so, did you remember to attach it to the theme? (pretty obvious, I know, but I forgot :slightly_smiling_face:)
very glad to works here now, and thx for point me in the right directions, but some problem is here, a component which is apply the them has impediment the source works, when I’ve had a more clear idea was is the component I’ve wrote here.
Regards.,
I’ve found and this is the source:
→ discourse-custom-code/common at main · discourse/discourse-custom-code · GitHub
p > code,
li > code,
pre > code {
  color: dark-light-choose($code_light, $code_dark) $i;
  background: dark-light-choose($code_background_light, $code_background_dark) $i;
you can do it without tweaks CSS, just use that component and modify:
  • color light.
  • color background light.
  • code dark.
  • code background dark.
NOTE
however this works for both inline code and block-code.
Regards.,
Seems the proper link should be Custom Code
