Hi,
Can i keep a log for 404 not found pages?
Like that pattern:
date - url -how many time
Hi,
Like that pattern:
You should be able to use Google Analytics to get that info.
I am already use Analytics. I should get the info on Analytics panel, right?
No – if you’re using GA you get that data directly from the GA interface, rather than through the Discourse UI.
Edit: I made an assumption about what you meant by the Analytics panel.
It’s not that easy to be honest.
You need to either make a custom javascript file to check if “Oops! That page doesn’t exist or is private.” exists, or change the 404 template to fire an event. So no, this is not out of the box and also it’s a bit fragile.
I would agree that this feature is useful; especially in the days directly after a migration.
We’re about to customize our 404 page using tips from: Customize the 404 page ("Oops! That page doesn't exist or is private")
Is the information in this topic still relevant?
I don’t believe this has changed.
One way that might make it easier to track in Google Analytics is if we update the page title to something like 404 not found - forum name — In GA you can create a custom report that filters for page title without any custom JS or events.
C’è un modo per aggiornare il titolo della pagina per le pagine 404?
Qualsiasi testo in Discourse può essere personalizzato. Nel tuo caso, dovrai modificare page_not_found.title da /admin/customize/site_texts/page_not_found.title
Mi scuso, mi riferisco al titolo della pagina nella sezione head che appare nella scheda del browser. Non sono riuscito a trovare alcuna personalizzazione del testo correlata a questo.
