Puis-je créer un plug-in pour afficher un certain groupe de personnes ?
Can I make a plug-ins to assign a certain group of people?
for example : Staff
  • Metric
  • Static
  • and so on
I’m not sure I understand what you’re asking.
The question is if you need a plugin to extract statistics from a group to see them?
In this case no, you do not need to write a new plugin if you want to collect statistical data you can use the Data Explorer plugin.
If you want to display them somewhere on Discourse you will need at least a theme, but most likely yes, you will also need a plugin.
Do you mean something different from the groups already supported by Discourse? You can create groups. Groups are collections of users.
Are you talking of DM groups or in-general?
In general. See /groups and /admin/groups.
