האם ניתן לאפס את תאריך ה-bump של מספר פוסטים בבת אחת?
We made changes to alot of posts and all of them are now displaying on the home page
Is there a way I can reset the bump date for multiple posts with a click?
A few clicks…
Select your topics then click the cog and Reset bump dates.
What exactly does this reset them to?
The time and date they had before the edit.
It don’t change the date but don’t use the edit date to showing ‘up’ on lists.
So with that function we can edit without ‘bumping’. I suspect that supposed to be the default behavior and ‘un-bump’ should be ‘bump’ :grimacing:
thank you. it worked.
