Kan geen formulier-sjabloon scrollen op mobiel
A bug was reported by Heliosurge regarding the inability to scroll form templates on mobile devices (specifically LG G8 ThinQ), preventing users from reaching the “Create Topic” button. The issue was also noted by Don and confirmed by JammyDodger, who split the report into a dedicated bug topic for tracking. Fortunately, JammyDodger later confirmed the bug has already been fixed in a recent pull request (https://github.com/discourse/discourse/pull/24019), and users are advised to update to the latest version to resolve the issue. Heliosurge expressed appreciation for the quick resolution and the creation of the bug report topic.
Awesome new feature!
I have run into an issue using the demo template. On my Mobile LG G8 ThinQ.
I cannot scroll template to press create topic. On my Tablet there is enough vertical real estate to be able to press it
Top screen button for create Topic only gives option to start a fresh topic.
Running Tests- passed uptodate.
Thanks for the report @Heliosurge.
Don mentioned this as well, and I’ve encountered a similar issue:
I’ve split your post off into a dedicated Contribute > Bug topic so we can track it better. :+1:
Turns out this has already been fixed in:
If you update to latest everything should be sorted. :+1:
Your quite welcome and thanks for splitting to bug report topic.
Awesome to see a fix has already bern pushed out!
This topic was automatically closed after 3 days. New replies are no longer allowed.
