Mobile: Can't scroll in area next to pagination/scroller widget
When inside of a topic on mobile, trying to initialise a scroll in the area next to the pagination/scroller widget doesn’t work. This is only the case when the widget is not fixed to the viewport, i.e. only when you’re at the bottom of the page.
Since this is usually the biggest “empty” area on the page, I run into this issue quite frequently.
I’ve marked the affected area red in this screenshot:
In case this is browser-specific, I’m using Firefox Nightly on Android.
This topic is related with this…
Thanks, this should fix it: https://github.com/discourse/discourse/pull/15840
This topic was automatically closed after 21 hours. New replies are no longer allowed.
