Has someone been able to deploy discourse via App engine?What the best Steps to be taken incase you want to deploy discourse in GCP?
- Using Compute Engine
- Via App Engine
- Kubernetes Cluster
The official install is always the best way to install discourse
Build an image with launcher, push it to somewhere, have app engine run it with the appropriate environment settings.
@pfaffman Could you please elaborate the steps to be followed to deploy via App engine Flexible Environment.
That’s my best answer for your desired deployment. The first step would be to do a standard installation and see the container that it creates and the command used to launch it. Perhaps if you do that first then the steps I provided might make more sense.
If you have a budget, feel free to contact me or post in Marketplace .
