User’s biography on user card is limited on 3 line of text.
Can we get some kind of link and visual indicator that there is more lines and rest of info inside biography of users.
I know that you can click on avatar to go to user info end there is full bio.
But usually users do not know for that.
Users card is clicked for user info if I can’t figure from there that his bio is more then 3 lines I am not going to click on his avatar.
If bio contain more then 3 line can We get link at end [MORE] or [FULL BIO] .
There is […] but only if is 3th line full of text.
Yes, some link to the users full profile would be really great to have. I was hoping that I could do some quick fix via CSS but there seems to be no straight forward solution.
This is visible when a user clicks on the profile icon of topic for a member of the community.
I have highlighted some text in this screenshot, this text is actually separated into a separate paragraph in the main profile view, but the user card ignores the spacing and scrunches it up. This makes the use of the composer when detailing your profile a little wasted.
I wondered whether it would be possible to not do that, and instead, insert a More… (or Read more…) link;
The link, if clicked, would behave like the second click on the profile icon, e.g. the user is taken to the main profile view where, for everyone other than the user themselves, the profile is expanded fully and thus the text would be readable.
I don’t think it’s overly obvious to users that another click is required to get them to the full profile view, and the wording in a link like the one suggested, or similar, would perhaps provide some affordance.
I don’t know if there are any logs which would indicate usage, but my feeling is that viewing of a users full profile is under used, for want of a better phrase, and my feeling is that this is because some people will see the profile card and assume that’s it,not realising they can click through.
It would be my hope that being more obvious, people may read other users profiles more often and increase the “getting to know you” aspect of a community.
Ah, if that’s the case then it probably doesn’t really help support my suggestion at this time, and yes, I would agree that more granularity on that report would help, but probably only for this very specific purpose.
Not sure if there’s a query that could maybe provide for the Data Explorer which could be just used for this etc.
If it turns out that most of our 50 a day are only card views then I would like to think that perhaps this supports the notion of having some other affordance on the card to encourage users to view the whole profile. The mouse point does obviously change to a hand when you move it over the persons name or profile image, but I kinda stumbled across that, as opposed to thinking that it would take me to more information. This wouldn’t obviously help on a mobile device as you don’t have the pointer.
I would agree that clicking the avatar a second time is not user friendly/discoverable at all, especially for non-tech geeks like us. I have a user base that has a lot of older people and this is not intuitive to them especially. Since launching my site I have had to answer the question of how to view the full profile numerous times. This is what I would propose:
