Не удается собрать для arm: ошибка Zlib::BufError во время assets:precompile
На VPS Hetzner CAX21 с процессором aarch64 при запуске ./launcher rebuild web.yml процесс аварийно завершается со следующей ошибкой: Пожалуйста, помогите.
I, [2024-05-24T14:07:05.408434 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30: warning: /usr/local/lib/ruby/3.3.0/observer.rb was loaded from the standard library, but will no longer be part of the default gems since Ruby 3.4.0. Add observer to your Gemfile or gemspec. Also contact author of rmagick-4.2.2 to add observer into its gemspec.
Purging temp files
Bundling assets
I, [2024-05-24T14:07:12.220787 #2680]  INFO -- : Writing /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js
I, [2024-05-24T14:07:12.229550 #2680]  INFO -- : Writing /var/www/discourse/public/assets/service-worker-f149bdcc45f1996961aa7d1e44bbaaa67fbfc013f6976595afe544acfe5664dc.js
I, [2024-05-24T14:07:12.248203 #2680]  INFO -- : Writing /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js
I, [2024-05-24T14:07:12.253509 #2680]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
I, [2024-05-24T14:07:13.226151 #2680]  INFO -- : Writing /var/www/discourse/public/assets/locales/ar-6e08f3f970e658a14b18a835d3c1fb286846ea94e333ac46242e166eff29dd22.js
I, [2024-05-24T14:07:13.682780 #2680]  INFO -- : Writing /var/www/discourse/public/assets/locales/be-762dabfdc99a559d5cf6fb691049fb50a71fa828e3dd48818a94dc62dc988f71.js
I, [2024-05-24T14:07:14.148990 #2680]  INFO -- : Writing /var/www/discourse/public/assets/locales/bg-28b8fd14f6bcc195da7401a451a222ccc958e1b285df4bb7e95d65f356bad2ec.js
I, [2024-05-24T14:07:14.431154 #2680]  INFO -- : Writing /var/www/discourse/public/assets/locales/bs_BA-34f2fe1480f5a9c77ddf0dfb26ad4751e793ce56b1cc48e9ad6e9867c5e08094.js
rake aborted!
Zlib::BufError: buffer error (Zlib::BufError)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache/file_store.rb:100:in `<<'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache/file_store.rb:100:in `set'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache.rb:212:in `set'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache.rb:136:in `set'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:243:in `store_asset'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:185:in `load_from_unloaded'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:60:in `block in load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:317:in `fetch_asset_from_dependency_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cached_environment.rb:20:in `block in initialize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cached_environment.rb:47:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/bundle.rb:23:in `block in call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/utils.rb:201:in `dfs'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/bundle.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/processor_utils.rb:75:in `call_processor'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/processor_utils.rb:57:in `block in call_processors'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/processor_utils.rb:56:in `reverse_each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/processor_utils.rb:56:in `call_processors'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:134:in `load_from_unloaded'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/base.rb:66:in `find_asset'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/base.rb:73:in `find_all_linked_assets'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:134:in `block in find'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:133:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:133:in `find'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:186:in `compile'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-rails-3.4.2/lib/sprockets/rails/task.rb:67:in `block (3 levels) in define'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/rake/sprocketstask.rb:147:in `with_logger'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-rails-3.4.2/lib/sprockets/rails/task.rb:66:in `block (2 levels) in define'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Tasks: TOP => assets:precompile
I, [2024-05-24T14:07:14.967828 #1]  INFO -- : Downloading MaxMindDB...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 2678 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"precompile", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile'"]}
26e64935c29000e8c019ed676034a16e2d988ec28a2cd9164e142ee83c086ded
root@ubuntu-8gb-nbg1-1:/var/discourse#
После закомментирования некоторых плагинов сборка снова стала работать. Давайте определим, какой именно плагин вызывает проблему.
В конце концов выяснилось, что проблему вызывает плагин https://github.com/discourse/discourse-animated-avatars и сопутствующий ему скрипт. Если закомментировать строку клонирования плагина и
- exec:
    cd: $home/plugins/discourse-animated-avatars
    raise_on_fail: false
    cmd:
      - $home/plugins/discourse-animated-avatars/scripts/install.sh
… то всё заработает.
У меня та же проблема, и когда я отключаю часть exec в discourse-animated-avatars, пересборка работает.
Связываю с недавним похожим сообщением Rebuild fails when these plugins are present - #5 by JammyDodger, хотя там не было Анимированных аватаров. Первичные предположения касались Подписок.
Оказывается, если убрать комментарии из части install.sh и выполнить сборку во второй раз после того, как она прошла успешно в первый раз без части install.sh, то сборка проходит и с ней. Странно…
Я не думаю, что дело было в подписках. Я удалил подписки, и всё ещё работало. Затем я закомментировал ключ и ID MaxMind, и снова всё заработало. Получается, что у MaxMind что-то всё ещё сломано. Просто не имеет смысла, что проблема с MaxMind приводит к сбою всей сборки. Я попробую ещё немного поработать, чтобы понять, в чём именно проблема, но пока просто сделаю так, чтобы ошибка MaxMind не останавливала процесс полностью.
Мое предположение на данный момент: могут возникать ложные ошибки, например, проблемы с сетью, перегрузка их серверов, ограничение частоты запросов или что-то подобное, из-за чего возвращается мусор, который не удаётся распаковать (поскольку это не ZIP-файл).
Этот код MaxMind недавно был переработан для пары ID/ключ. Меня расстраивает, что ошибка «MaxMind вызывает сбой сборки» сохранилась. (По крайней мере, так кажется).
