Cannot delete user
I still cannot repro this :disappointed:.
I have a group autogroup that all users with gmail.com emails are added to, including existing users, and set a primary. I can still delete a user who signs up using Google oAuth2 or via local logins and is added to the group.
Group settings screenshot
I’m running into this problem now too on my site. There are a few test user accounts I created - one of them a staged user - and I am unable to delete them. I try to delete the user’s posts via the user admin, but it has no effect.
Have you tried out Michael’s workaround ? (if applicable)
thanks, but that workaround did not work for me - no group auto-add for the user’s email domain.
I am also having issues with anonymizing or deleting users, when I go to /admin/users/list/active and attempt to delete or anonymize any user who has last_emailed_at set to -- the system errors out.
What is the specific error? Is there an entry in the logs?
When trying to delete from admin, is it giving no response and then later you get an error message? I’ve seen that recently.
I get the error message that @tobiaseigen posted above when going through the UI. When I attempt to anonymize I get a pop up that reads,
There was a problem anonymizing the account.
Looking at production.log I can see the following:
Started DELETE "/admin/users/8911.json" for {BLOCKED_IP} at 2018-04-20 17:03:11 +0000
Processing by Admin::UsersController#destroy as JSON
  Parameters: {"context"=>"/admin/users/8911/{USER}", "delete_posts"=>"true", "id"=>"8911"}
Completed 500 Internal Server Error in 320ms (ActiveRecord: 84.9ms)
Aws::S3::Errors::AccessDenied (Access Denied)
Started PUT "/admin/users/8911/anonymize.json" for {BLOCKED_IP} at 2018-04-20 17:02:08 +0000
Processing by Admin::UsersController#anonymize as JSON
  Parameters: {"user_id"=>"8911"}
Completed 500 Internal Server Error in 513ms (ActiveRecord: 44.2ms)
I am using AWS S3 for hosting attachments, however this user does not have anything in there. I will play around with AWS IAM permissions and see if I can resolve this, looking at CloudWatch I do NOT see any errors pertaining to this.
Can you give some more info on how we could replicate this locally?
Are these test users or actual users? Are they part of any groups? Do they have any posts or pms?
I think in my case they are all staged users.
don’t have time just now to look in the logs - will come back to this later if you still need my help.
thanks for looking into this! :sunflower:
Like a user that was created because they emailed in?
yep. though in this case they were created because I emailed out to them by creating a new message including their email address.
when I try to delete one of my staged users, I get this in the error log:
/var/www/discourse/plugins/discourse-assign/lib/topic_assigner.rb:164:in `unassign' /var/www/discourse/plugins/discourse-assign/plugin.rb:195:in `block (2 levels) in activate!' /var/www/discourse/lib/plugin/instance.rb:258:in `block in on' /var/www/discourse/lib/discourse_event.rb:12:in `block in trigger' /usr/local/lib/ruby/2.4.0/set.rb:324:in `each_key' /usr/local/lib/ruby/2.4.0/set.rb:324:in `each' /var/www/discourse/lib/discourse_event.rb:11:in `trigger' /var/www/discourse/app/models/post_action.rb:157:in `agree_flags!' /var/www/discourse/lib/post_destroyer.rb:197:in `agree_with_flags' /var/www/discourse/lib/post_destroyer.rb:115:in `block in perform_delete' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:233:in `transaction' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/transactions.rb:210:in `transaction' /var/www/discourse/lib/post_destroyer.rb:107:in `perform_delete' /var/www/discourse/lib/post_destroyer.rb:50:in `destroy' /var/www/discourse/app/services/user_destroyer.rb:40:in `block (2 levels) in destroy' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/relation/delegation.rb:39:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/relation/delegation.rb:39:in `each' /var/www/discourse/app/services/user_destroyer.rb:27:in `block in destroy' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `block in transaction' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:194:in `block in within_new_transaction' /usr/local/lib/ruby/2.4.0/monitor.rb:214:in `mon_synchronize' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:191:in `within_new_transaction' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `transaction' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/transactions.rb:210:in `transaction' /var/www/discourse/app/services/user_destroyer.rb:21:in `destroy' /var/www/discourse/app/controllers/admin/users_controller.rb:369:in `destroy' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:16:in `block in <class:Constraints>' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.1/lib/rack/protection/frame_options.rb:31:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/conditional_get.rb:38:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/head.rb:12:in `call' /var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:232:in `context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:226:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call' /var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/method_override.rb:22:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/sendfile.rb:111:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus/rack/middleware.rb:63:in `call' /var/www/discourse/lib/middleware/request_tracker.rb:176:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:68:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
The users which are not deleting for me were created but not activated in previous Discourse version. I recently updated to the latest version of Discourse and attempted to delete them and ran into errors. I’m not sure if this is a coincidence or if it is the root cause of this problem.
I can’t delete a user. I’ve deleted all posts, and it failed, so I deactivated and reactivated, but still no joy. I anonymized, and still no luck. I get the same error. No groups or auto-groups set up for this user.
Version
Installed
[v2.1.0.beta3 +31]
Latest
2.1.0.beta3
You’re up to date!
私も同じ問題が発生しています。説明されているのと同じエラーで、複数のユーザーを削除できません。
これらのユーザーに定期的な投稿がない場合、彼らが何らかのグループに所属しているか確認し、スタッフ以外のユーザーから私信(PM)を受け取ったか、または私信を送ったかも確認してください。
ユーザーはデフォルトの信頼グループに所属しています。同じメンバーシップを持つ別のユーザーの削除はできました。複数のPM(プライベートメッセージ)が表示されますが、それらを削除することはできません。Discourseでユーザーを削除するのは非常に厄介です。
更新:
解決策として、delete_user_max_post_age を2年に設定しました。これで、すべてのメッセージとユーザー自体を削除できるようになりました。さらに、delete_all_posts_max を増やす必要がある場合もあります。
