Cannot "not filter" with Show Filter by Tag option
With the Show a dropdown to filter a topic list by tag option selected, it is not possible to “clear” or “disable” the tag filter; the only options are:
all tags
no tags
tag x
tag y
etc…
It should be possible to have an unfiltered view here, as all tags and no tags are mutually exclusive.
I’m missing what you’re getting at.
Isn’t “all tags” the same as unfiltered?
Maybe a screen capture that shows the difference between the lists?
Gif is too big to upload here, so see on giphy: http://www.giphy.com/gifs/3o7TKtc9Z0kDvhLE3K
Basically, “all” does not include “none”, and vice versa.
Oh, so “all” is behaving as “any tag” which of course doesn’t include “no tags”.
