Summary: Discourse Tagging Plugin show filter by tag function seems to have a few bugs
Steps to reproduce:
Install and enable Discourse Tagging Plugin
Enable show filter by tag
Create >30 tags
Open tag filter drop down on Latest view
Expected Results:All used tags listed in menu, with all and none options in alphabetical order
Actual Results: Only 30 tags are listed, no none option, seem to be sorted by frequency of use
Notes: Unable to attempt repro of this on meta or try as filter by tag is not enabled.
Edit 12/1/15: Informed of configuration option in admin panel to control number of tags. Still believe lack of none option to be a bug as compared to category filter.
Not an admin, only a moderator. Did not know that was a user-configurable setting. Still believe the lack of “none” as a filter option is a bug (at when comparing this drop down to category filtering).
There’s already a filter that you can use in search. Use the tags: prefix and comma-separated list. For example tags:themes,dark-theme. This raises the issue of whether that’s an OR or an AND query. It’s an OR. There’s currently no way to search for topics tagged themes AND dark-theme. It’s needed, so we’ll need to figure out how to expose that.
And I agree that there should be a way to see an option of “none” in the tags filter.
Was starting work on this, but the tag filter is busted right now. It disappears after one use of the category dropdown and is gone for good. Will get back to this once that’s fixed.
The tag filter is fixed, and the “no tags” filter has kinda been added… It works, but I need to figure out the ember for one last part of it.
Even when no tags is chosen and the list shows the correct results, the dropdown shows “all tags”. Gotta figure out how to make the dropdown say “no tags”.
