Cannot see hidden posts
The discussion revolves around the visibility of hidden posts in a Discourse forum. Kevin_Lu1 asks how to view flagged posts, noting that the option to unhide them is missing. Moin explains that visibility of hidden posts is controlled by a setting, allowing only specific groups and staff to view them. Kevin_Lu1 clarifies he is a regular user, prompting Moin to emphasize that non-staff users should not view hidden content to avoid encouraging bad behavior. Ondrej adds that the current behavior has been in place since June last year and that users should focus on productive discussions. Kevin_Lu1 admits he doesn’t visit often and only recently noticed the change.
Hello, is there a way to see flagged/hidden posts, because in one of the discourse forums there isn’t an option to unhide it. Thanks.
Hello @Kevin_Lu1, welcome to Meta :discourse: :tada:
There is a setting that controls which users can see the button to unhide a hidden post.
hidden_post_visible_groups: Allow members of these groups to view hidden posts. Staff users can always view hidden posts.
What if I’m a basic user and not a staff member?
Why do you need to view it?
I’m afraid you’ll have to wait until a moderator addresses the flag. They can make it visible again if they disagree with the flagging.
Usually, there is a reason why a post was flagged, and then it can keep the discussion civil and on topic. If basic users are able to view the hidden content, they tend to react to the hidden post.
Since the default rules also say that you should not react to those posts, hiding them is often better. Otherwise, moderators have to look for those reaction posts and delete them too.
When you see bad behavior, don’t reply. It encourages the bad behavior by acknowledging it, consumes your energy, and wastes everyone’s time. Just flag it . If enough flags accrue, action will be taken, either automatically or by moderator intervention.
Of course, you could also ask the staff to change the setting.
Oh ok, that makes more sense. I just want to see it to see what he said was so controversial :joy:
This setting was also newly integrated so I was able to view hidden posts before.
This has been the case since June last year.
But as Moin said above, its best to let flagged posts be. Its best to focus on the productive posts in a topic :wink:
I don’t visit the forum often so I just realized it :joy:
