iLek2428
(ไก่จิกดตฎฏบปอ )
10 أكتوبر 2014، 8:17ص
1
[root@iLekLoveAnswers docker]# /var/docker/launcher bootstrap app
which: no docker.io in (/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
Calculated ENV: -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=3 -e UNICORN_SIDEKIQS=1 -e RUBY_GC_MALLOC_LIMIT=40000000 -e RUBY_HEAP_MIN_SLOTS=800000 -e DISCOURSE_DB_SOCKET=/var/run/postgresql -e DISCOURSE_DB_HOST= -e DISCOURSE_DB_PORT= -e HOME=/root -e DISCOURSE_DEVELOPER_EMAILS=me@example.com -e DISCOURSE_HOSTNAME=discourse.example.com -e DISCOURSE_SMTP_ADDRESS=smtp.example.com
cd /pups && git pull && /pups/bin/pups --stdin
fatal: unable to access 'https://github.com/SamSaffron/pups.git/': Could not resolve host: github.com
0b40c83cfcd4bde7b880485c2153e240ac38d0466f819262599a72f680b4b2b2
FAILED TO BOOTSTRAP
What should I do?
downey
(Michael Downey)
10 أكتوبر 2014، 12:25م
3
It looks like you don’t have docker successfully installed. What happens when you run this?
$ sudo docker info
If you get docker: command not found or something like /var/lib/docker/repositories: permission denied you may have an incomplete Docker installation or insufficient privileges to access Docker on your machine.
Which documentation did you use to install Discourse?
iLek2428
(ไก่จิกดตฎฏบปอ )
10 أكتوبر 2014، 1:27م
4
$ sudo docker info
Containers: 3
Images: 16
Storage Driver: devicemapper
Pool Name: docker-252:1-265165-pool
Pool Blocksize: 64 Kb
Data file: /var/lib/docker/devicemapper/devicemapper/data
Metadata file: /var/lib/docker/devicemapper/devicemapper/metadata
Data Space Used: 2783.2 Mb
Data Space Total: 102400.0 Mb
Metadata Space Used: 2.4 Mb
Metadata Space Total: 2048.0 Mb
Execution Driver: native-0.2
Kernel Version: 2.6.32-431.1.2.0.1.el6.x86_64
Operating System: <unknown>
This is not supported. Sorry.. we see lots of badness with devicemapper. You need to get AUFS working.
iLek2428
(ไก่จิกดตฎฏบปอ )
11 أكتوبر 2014، 5:44م
6
I removed the left Centos
And change it to Ubuntu-based guidelines.
successfully passed
