Can't add more more than 300 emails to email domain whitelist
A user reports an issue with adding email domains to the whitelist in Discourse, encountering an error when trying to save changes after reaching around 300 domains. The error is non-descriptive, and the user provides a log showing a problem in the site_setting_extension.rb file. Another user suggests the issue might be related to the size of the regular expression generated by the whitelist, while the original user confirms the problem persists even after removing domains. A fix is referenced in a GitHub commit here.
Hello! We require whitelisting all of the email domains on our site. Today, we tried to add a new one and encountered an error.
I went to the ? menu > Admin > Login > email domains whitelist.
I can add the email domain and it lets me create a new one, but when I click the green checkmark to save, I get the following, non-descriptive error:
whitelist_error
Any suggestions?
How many email domains have you already added ?
When you click the button to add more domains and you get the error go to the logs on your site and check for errors (if there are any, share them here) .
We have around 300 whitelisted at this time. We need to whitelist every domain from our customers. I can’t add an attachment yet, but here’s the log:
/var/www/discourse/lib/site_setting_extension.rb:347:in `get_hostname' /var/www/discourse/lib/site_setting_extension.rb:258:in `block in filter_value' /var/www/discourse/lib/site_setting_extension.rb:258:in `each' /var/www/discourse/lib/site_setting_extension.rb:258:in `filter_value' /var/www/discourse/lib/site_setting_extension.rb:266:in `set' /var/www/discourse/lib/site_setting_extension.rb:276:in `set_and_log' /var/www/discourse/app/controllers/admin/site_settings_controller.rb:16:in `update' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:16:in `block in <class:Constraints>' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.1/lib/rack/protection/frame_options.rb:31:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/conditional_get.rb:38:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/head.rb:12:in `call' /var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call' /var/www/discourse/config/initializers/008-rack-cors.rb:25:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:232:in `context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:226:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/lograge-0.7.1/lib/lograge/rails_ext/rack/logger.rb:15:in `call_app' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call' /var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/method_override.rb:22:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-2.0.4/lib/rails_multisite/middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/sendfile.rb:111:in `call' /var/www/discourse/plugins/discourse-prometheus/lib/middleware/metrics.rb:17:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus/rack/middleware.rb:63:in `call' /var/www/discourse/lib/middleware/request_tracker.rb:176:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:68:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
Not 100% sure but i suppose email domain whitelisting works with regexp except for the dot character. Maybe you can consider using regexp to trim down on the list?
Your 300 domains is gonna create a huge regexp in discourse…
Stephen, I’m afraid I don’t really know what that means. In case we hit on some arbitrary limit, I tried removing one and adding another, but it still won’t let me save. It won’t let me save any changes, not just adding them.
In that case did you check the error logs?
Fix here
