Email domain blacklist with wildcards (revisited)
The current implementation of the email domain blacklist in Discourse uses EndsWith type string matching. schungx proposes adding regex type matching to filter out spammers with email addresses containing a long string of numbers.
After investigating the code, schungx found that the domain string is passed into a regex, but the regex inside #{domains} cannot use the dot .. schungx attempted to use a regex in the blacklist domain, but it did not filter out spammers as expected.
schungx wonders if the settings require a VM restart to take effect. Further investigation schungx reveals that EmailValidator is not used to verify staged users created via email in. schungx suggests calling EmailValidator.validate_each on @from_email to check if the incoming email is from a blacklisted domain.
A bug report has been created by schungx to address the issue of the email domain blacklist not being consulted when receiving emails and creating staged users.
The current implementation already matches black-listed domains with EndsWith type string matching.
I would like to propose adding regex type matching as well.
Reason: Recently a lot of spammers come from email addresses with a long string of numbers, for example 76987.com, 245934.net etc.
I would like to be able to filter them out, but with the standard EndsWith matching, it is impossible.
EDIT:
Oops, just looked through the commit. Seems like the domain string is passed straight into the regex:
regexp = Regexp.new("@(.+\.)?(#{domains})", true)
Not sure if #{domains} gets sanitized before-hand. Unlikely because of the line:
domains = setting.gsub('.', '\.')
which only sanitizes the dot.
But it does appear to support putting a regex inside #{domains}, except that the regex cannot use the dot .
I’ve tried it with the following blacklist domain:
\d+\d\d\d.\w+
which should match any domain which is made up of four or more numbers (and numbers only).
I checked the setting with Data Explorer and confirms that email_domains_blacklist is mailinator.com|cc|\d+\d\d\d.\w+, which is correct.
The code regexp = Regexp.new("@(.+\.)?(#{domains})", true) should now filter off emails coming from domains with long digits.
EDIT: Note: not sure what the second parameter true is doing in a call to Regexp.new(), which takes as a second parameter the matching options.
However, I just had three new SPAMmers came through:
ddef@445555.com
mnopp@89990001.com
gg5@996399.net
So obviously it is not working.
Trying the RegExp in a JavaScript console confirms that it works:
/@(.+\.)?(mailinator\.com|cc|\d+\d\d\d\.\w+)/.test("ddef@445555.com")
true
There, the domain blacklist is not working as it should.
I wonder… does it require restarting the VM for the settings to “set”?
Tracing through the code, there is something very suspicious.
EmailValidator seems to be only used when a user updates his/her email address (in EmailUpdater).
When a user is created, it only validates against proper email format but not whether the email domain is blacklisted.
Emphatically, it is not used to verify when a staged user is created via email in, because email/receiver.rb, in process_internal, it only checks against things:
Regexp.new(SiteSetting.ignore_by_title) =~ @mail.subject  // Blacklisted TOPIC TITLE
raise BouncedEmailError  if is_bounce?  // Bounce mail
raise NoSenderDetectedError if @from_email.blank?    // No From field
raise ScreenedEmailError if ScreenedEmail.should_block?(@from_email)   // Screend Email address
After this, a new staged user is created via find_or_create_user.
Shouldn’t EmailValidator.validate_each be called on @from_email to make sure that the incoming email in is not from a blacklisted domain?
Or, better, check first if the user with that email address already exists. If so, let it pass. Otherwise, call EmailValidator.validate_each to check if it is blacklisted. DO NOT create a staged user if the email is blacklisted.
Created bug report. Hope I got it right. :grin:
