Hi there, I’m trying to help a user that was imported from my Drupal forum into Discourse with a password reset email. We’re having trouble with the primary address, and so I added a secondary one to his profile. But he says it says that no such registered email exists when he tries to request a password reset. So I tried to change the secondary to primary and the primary to secondary. But the change simply gets reverted, it won’t stick. And now Discourse is telling me (the admin and moderator) “You’ve performed this action too many times” when I try to change it (using a different browser in Discourse safe mode, just to eliminate that as the cause of the problem). I found this tip for changing it in the Rails console, but it doesn’t look right where it says wmail instead of email :
A user, rahim123, reports an issue where they cannot change a user’s primary email after importing from a Drupal forum. Despite attempts to switch the primary and secondary emails, the changes revert, and the admin receives a “too many actions” error. pfaffman suggests checking for hidden characters or case issues in the email, while sam requests more details, noting the issue may not be clearly a bug. Anmol_Saini provides a working solution using the Rails console to update the email via the user’s ID.
So try it without the typo. ![]()
Thanks Jay. It doesn’t seem to work:
SyntaxError: unexpected label, expecting ')'
..._id: u.id).first.update (email: "user@email.com")
SyntaxError: unexpected ')', expecting end-of-input
...email: "user@email.com")
Re-categorizing this as a bug, as the UI should always allow changing a user’s email and it shouldn’t rate-limit the admin.
Would clearing the Redis cache help I wonder?
There were two more typos in that.
I don’t think so.
My best guess is that you imported the email address with caps or some hidden character, perhaps. I would try to change to a different email rather than add a secondary.
Hmm, nope, the address is good, I pasted it into my email client and sent a message to it. I did try to change the primary, but it just keeps the primary and puts the secondary one after as unverified.
It is unclear what the bug is from the first post. I am moving back to Support
Please see:
We need more info here.
Hi there, I’m sorry if there wasn’t enough information, but I honestly don’t understand what was missing. I did try it with safe mode as mentioned earlier.
Is this the expected behavior?
I would say that the administrator should never be rate-limited.
This worked for me
u=User.find_by_username("XXXXXX")
UserEmail.find_by(user_id: u.id).update(email: "XXXX@XXX.com")
