Can't Manually Block/Whitelist an IP Address
A moderator at our instance tried to add an IP address to the blocked list, but nothing happens. It isn’t added (as far as I can tell) and there is no feedback. And the drop-down which I’m sure used to give options for Block/Allow no longer does so.
I updated my dev and test machine to latest and can repo. Can’t try this on Try as I don’t have Moderator abilities.
and
Firebug says:
إعجابَين (2)
Hmmm, having a look.
إعجابَين (2)
Thanks for reporting that issue @cpradio. Not sure for how long it has been broken…
4 إعجابات
