If you rebuilt the app then the changes made in the container are gone. Perhaps the backblaze folks fixed things while you were doing that.
I just commented out the S3 and rebuilt. I guess Iâll stick to local storage from now on.
Local storage works fine. Itâs just deleting that does not work.
Thanks for posting and confirming there is no current workaround without downgrading the aws SDKs. I ran into issues with the b2 s3 apis from another project using the golang aws sdk, trying to back up a VictoriaMetrics database.
Do you have any sense from your engineering team how or when they may choose to resolve this issue, or have any way to track/get updates on a supported workaround? Iâm trying to decide if I should fork and recompile a project with a dependency change or just wait a little while for an update!
Thanks!
The following procedure worked for me to downgrade the AWS Gems:
# To get into the container:
./launcher enter app
# Apparently needed to unfreeze Gemfile.lock:
bundle config set frozen false
# Set an older version of the sdk-s3 gem:
sed -i 's/gem "aws-sdk-s3", require: false/gem "aws-sdk-s3", "1.177.0", require: false/' Gemfile
# Downgrade the S3 gem to match what's now in the Gemfile:
bundle update aws-sdk-s3
# Also downgrade aws-sdk-core gem:
bundle add aws-sdk-core --version 3.215.
After making these changes, I was able to successfully save a backup to B2. Iâm sure this is only a temporarily workaround that will be lost on the next Discourse update, so Iâm hoping @PatPatterson and the Backblaze team can provide a more permanent compatibility fix soon.
Hopefully you wonât need to do this, but itâs possible to put that sed command in the app.yml so that it would happen automatically when you rebuild. I think just sticking it below where the plugins get cloned would do it. But it could be more complicated than I think.
Hi AntiMetaman,
I have spent the last week trying to get backups working with s3 storage and finally got the backup to work with this thread. Honestly, I am not sure which part worked.
I followed what you did with the gem uninstall and install but now I get an error trying to upload images. My error log shows this
not entitled /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.219.0/lib/seahorse/client/plugins/raise_response_errors.rb:17:in `callâ /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aw
Before I have to trash my whole server and start again (honestly, at this point Iâm not even sure I want to continue) do you know how I can reverse the gem uninstall and install so I can try and see if that fixes the issue?
The behavior Iâve seen on our instance (which uses backblaze for backup) is that backups started failing, without notification, in February. I just happened to notice it today, since I check our backups from time-to-time. I would consider this quite a serious problem?
Would it be possible to downgrade the AWS-SDK until a workaround can be found for backblaze and other non-AWS providers?
But I did for a site thatâs using Backblaze. I created a template I put in /root/aws-revert-template.yml with this:
# This template reverts aws-sdk-s3 to a version that works with backblaze
params:
home: /var/www/discourse
hooks:
after_bundle_exec:
- exec:
cd: $home
cmd:
- bundle config set frozen false
- "sed -i 's/gem \"aws-sdk-s3\", require: false/gem \"aws-sdk-s3\", \"1.177.0\", require: false/' Gemfile"
- bundle update aws-sdk-s3
- bundle add aws-sdk-core --version 3.215
And then added it to my app.yml like this:
# IMPORTANT: SET A SECRET PASSWORD in Postgres for the Discourse User
# TODO: change SOME_SECRET in this template
templates:
- "templates/web.ssl.template.yml"
- "templates/web.letsencrypt.ssl.template.yml"
- "/root/aws-revert-template.yml"
And I ran an upgrade to stable and it seems to be working.
You could also just add whatâs in the template to your app.yml
Noticed that this page - S3-Compatible API - no longer lists the various checksum-* headers as being unsupported.
@PatPatterson not sure if youâre still in this thread or not - but was official support added for those?
Can you confirm that your backblaze b2 is working without the fix I suggest?
Thanks for quick response, and sorry - I should have added more detail. In a different open source package (Mastodon) we wound up also locking the aws-sdk-core gem to be < 3.216.0 to handle this exact issue for people who are using backblaze (and I suspect others, but thatâs where it came up).
But then in last few weeks I noticed:
- That page on backblaze site no longers lists those headers as unsupported
- A recent aws gem release mentions fixing the issue where
when_requiredwas not fully honored previously
In previous research Iâd seen this thread with more or less the same issue and was trying to understand if we can safely gem update now if indeed backblaze has added that support, and/or the gem now fully works around the issue.
Hi - yes, Backblaze B2 added official support for the checksum headers earlier this year.
Excellent! Thanks for confirming.
