Installing Discourse With Plesk Onyx (Ubuntu 14.04)
Installing Discourse with Plesk Onyx (Ubuntu 14.04)
This discussion provides a step-by-step guide on installing Discourse with Plesk Onyx on Ubuntu 14.04.
Initial Steps
  1. Install Docker on Plesk Extensions.
  2. Install Redis and Nginx containers.
  3. Follow the official Discourse installation guide from the Discourse repository.
Port Configuration
  • Before running ./discourse-setup, edit discourse-setup and change check_ports() to use ports 8060 and 9443 instead of 80 and 443.
  • Update app.yml to use ports 8060 and 9443.
Common Issues
  • Email Issues: Make sure to update the SMTP settings in app.yml and rebuild the app.
  • SSL Issues: Ensure that the force_https site setting is enabled, and update the SSL certificates in app.yml.
  • Too Many Redirects: Enable “Permanent SEO-safe 301 redirect from HTTP to HTTPS” in Hosting Settings.
Additional Tips
  • Use Plesk’s own Nginx to proxy requests to the Discourse container.
  • Update the app.yml file to use the correct ports and SSL certificates.
  • Use the ./launcher rebuild app command to rebuild the app after making changes.
Backup and Restore
  • You can set up backups to Amazon S3 in the Discourse settings.
  • In case of a disaster, you can restore the entire instance from the old backup.
Troubleshooting
  • If you encounter issues, scroll up and look for earlier error messages.
  • Check the Discourse repository for troubleshooting guides.
Example Configurations
  • Canapin provides an example configuration for Plesk 17.8, Debian 8.11, and OVH VPS3.
  • SvenC56 provides an example configuration for Plesk, Nginx, and SSL.
Install Discourse on Plesk Onyx is simple!
Lie, I’ve been trying for two days until it works.
Update: This method will works with Ubuntu 14.04, 16.04 and Debian only.
First install Docker on Plesk Extensions.
Install Docker
https://content.screencast.com/users/DougasTeles/folders/Snagit/media/4f60c154-eec0-4493-a66e-17ec684e258c/07.04.2017-11.51.png
https://content.screencast.com/users/DougasTeles/folders/Snagit/media/67692595-d3bc-4529-a3d8-99a1c4c9eca4/07.04.2017-11.53.png
https://content.screencast.com/users/DougasTeles/folders/Snagit/media/e62dd341-791c-4773-9697-b764c8010af8/07.04.2017-13.03.png
Now install Redis and Nginx containers
Redis & Nginx
https://content.screencast.com/users/DougasTeles/folders/Snagit/media/ebf20e85-dcbe-49c2-96db-3bdd421761b3/07.04.2017-13.06.png
https://content.screencast.com/users/DougasTeles/folders/Snagit/media/310d1056-e131-4a71-aa0f-bb5ec50ea86f/07.04.2017-13.07.png
Go to discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub and follow this steps, starting on Install Discourse
Note: I forgot a detail. Before perform ./discourse-setup, you need edit discourse-setup.
Open discourse-setup with text editor, search for check_ports() { and change this:
check_port "80"
check_port "443"
To something like this:
check_port "8060"
check_port "9443"
Done.
After the fist installation, you get an error because 80 and 443 ports are in use by Plesk
Don’t worry!
Go to /containers/ and open app.yml with text editor (nano or wathever)
Find this lines:
  • “80:80” # fwd host port 80 to container port 80 (http)
  • “443:443” # fwd host port 443 to container port 443 (https)
Change to something like this:
  • “8060:80” # fwd host port 80 to container port 8060 (http)
  • “9443:443” # fwd host port 443 to container port 9443 (https)
Save and perform ./launcher rebuild app
Now, go back to Plesk panel, enter on your domain and find Docker Proxy Rules
Click on Add Rule
And select the app and port like this:
Now, open you domain on browser and boom! You are running Discourse with Plesk :slight_smile:
Nice work!
I’m pretty sure that you don’t need to install redis or postgres, as they are in the container.
Hi!!!
Congrats and thank you for this tutorial. I have problems with installation…
Just yerterday I installed a new website version, but now with discourse community discussion software:
https://ashesofcreation.es (in development)
comunidad.ashesofcreation.es (discourse)
I can’t install Let’s Encrypt certificate to subdomain (discourse app are inside)
Somebody could help me?
Thanks & Regards
JaPeMo
That looks like a question for Plesk folks, as that error comes from Plesk, not Discourse.
I think that is come from Plesk, but I don’t know what happen…
Hi and thanks for that!
Do you think it works on Centos 7?
I’ve just installed Plesk 17 (Onyx) and docker is already installed by default.
I’m just curious to see if Discourse can be setup there.
People often have trouble with Centos and docker, but if it’s already installed, perhaps it’s properly configured. If that’s the case, the install instructions should work just fine. Try it and see.
Do you think is it possible to install Discourse image straight away ?
That will not work. You need to follow the official install instructions on Github: discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
See Can Discourse ship frequent Docker images that do not need to be bootstrapped? for more details on why you can’t simply install the container.
Thanks for the article… I’m quite new to Discourse.
I tried installing it on my Debian Plesk system.
At first all seemed working fine… I did all as it is described above. But I had problems with discourse sending mails. So I changed the smtp settings (used mailgun) in app.yml and used ./launcher rebuild app
Afterwards discourse was not accessible via browser anymore…
I also tried to remove the container in plesk and running setup again but id didn’t help. I probably screwd up the installation even more…
Can anybody help?
thanks,
Dave
What was the result?
A lot of stuff scrolling over my screen… But as far as I could see without errors…
How can I uninstall everything and start from the beginning? Can I just delete the /var/discourse folder?
That’s great news! Show me your app.yml please, I’ll try to help you find out and fix the problem :slightly_smiling_face:
Thanks, here is the file:
  templates:
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "8060:80"   # http
  - "9443:443" # https
params:
  db_shared_buffers: "4096MB"
  #db_work_mem: "40MB"
  #version: tests-passed
 env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 8
  DISCOURSE_HOSTNAME: XXXXX
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'XXXXX'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: XXXXX
  DISCOURSE_SMTP_PASSWORD: "XXXXX"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
You could just delete app.yml (or rename it) and run. /disourse-setup.
Already tried that…
I guess that something with the port/proxy stuff went wront…
Yes, you’ll then need to edit it by hand (that is to say with nano or vim) and replace the ports as it was in your earlier example.
Yes, I also did that (using nano)… Deleted the old file run setup and than changed the ports.
I tried again, removed the discourse folder and started from the beginning…
Now I can’teven get it to run at all (maybe deleting the folder wasn’t such a good idea ):
2017-11-01 21:25:14.996 UTC [47] LOG:  database system shutdown was interrupted; last known up at 2017-11-01 21:19:10 UTC
2017-11-01 21:25:15.604 UTC [47] LOG:  database system was not properly shut down; automatic recovery in progress
2017-11-01 21:25:15.655 UTC [47] LOG:  redo starts at 0/170E300
2017-11-01 21:25:19.266 UTC [47] LOG:  invalid record length at 0/25C6630
2017-11-01 21:25:19.266 UTC [47] LOG:  redo done at 0/25C6608
2017-11-01 21:25:19.266 UTC [47] LOG:  last completed transaction was at log time 2017-11-01 21:11:57.661238+00
I, [2017-11-01T21:25:19.509808 #15]  INFO -- :
I, [2017-11-01T21:25:19.510076 #15]  INFO -- : > su postgres -c 'createdb discourse' || true
2017-11-01 21:25:19.578 UTC [51] postgres@postgres FATAL:  the database system is starting up
2017-11-01 21:25:19.580 UTC [52] postgres@template1 FATAL:  the database system is starting up
createdb: could not connect to database template1: FATAL:  the database system is starting up
I, [2017-11-01T21:25:19.581747 #15]  INFO -- :
I, [2017-11-01T21:25:19.582022 #15]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2017-11-01 21:25:19.647 UTC [63] postgres@discourse FATAL:  the database system is starting up
psql: FATAL:  the database system is starting up
I, [2017-11-01T21:25:19.649514 #15]  INFO -- :
I, [2017-11-01T21:25:19.649722 #15]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
2017-11-01 21:25:19.705 UTC [74] postgres@discourse FATAL:  the database system is starting up
I, [2017-11-01T21:25:19.707270 #15]  INFO -- :
I, [2017-11-01T21:25:19.707449 #15]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
2017-11-01 21:25:19.754 UTC [85] postgres@discourse FATAL:  the database system is starting up
I, [2017-11-01T21:25:19.755549 #15]  INFO -- :
I, [2017-11-01T21:25:19.755797 #15]  INFO -- : Terminating async processes
I, [2017-11-01T21:25:19.755835 #15]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 44
2017-11-01 21:25:19.755 UTC [44] LOG:  received fast shutdown request
I, [2017-11-01T21:25:29.756377 #15]  INFO -- : HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid:44 did not terminate cleanly, forcing termination!
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 75 exit 2>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
3bf8e9a04c7bf43219bb1b7ae3bb1c733345ba6074ea1068a070422e2d10fb5e
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
How can I correctely delete discourse completeley, so I can start all over?
thanks
Dave
You can
rm -fr /var/discourse
or
mv /var/discourse /var/discourse.broken
Then clone it again as per the install instructions.
