Can't send test email with Amazon SES
Hello!
I’ve got some issues on receiving the email. Checked all instructions but it isn’t work.
I’m using next configs:
config.action_mailer.smtp_settings = {
   address: 'email-smtp.us-east-1.amazonaws.com',
   authentication: :login,
   password: 'PWD',
   user_name: 'USRNAME',
   enable_starttls_auto: true,
   port: 587
Got this error when trying to test it.
“There was a problem sending the test email. Please double-check your mail settings, verify that your host is not blocking mail connections, and try again.”
My app.yml discourse’s configs:
Add DISCOURSE_SMTP_AUTHENTICATION: "login"
The same issue.
I’ve added this row:
 DISCOURSE_SMTP_ENABLE_START_TLS: true
and then ran ./launcher rebuild app
Also, when I’m trying to test it via telnet:
got this…
fixed issue.
Thanks for suggestion with SMTP Authentication config option.
I have created user in SES and everything working now
