update: I was able to get the ones I wanted uploaded by rebuilding the image several times. That really feels like a rate limiting issue to me… is it? I’d like to get to the bottom of this still so I know what to do in the future.
What’s strange here is that 400 is a client error. Uploading emoji to a Discourse instance shouldn’t then impact your client. So after you uploaded emoji, then deleted some, you can’t upload normal images to a post?
Have you tried a different device? Are you the only user experiencing the issue, or are there others?
As I said in my update, I was able to get around this by rebuilding the docker container a couple of times. I don’t think other people have tried to upload images; I do not know if they are blocked. I could not upload normal images while this was happening.
Right, but as you say in your first post, rate limits should give a 429 issue. At the moment I’m very hesitate to say this is a bug given a single report - if we had a rate limit issue for image uploads we’d be hearing about it.
If this occurs again, please confirm if it is device specific or not, so we can dig further.
