JSey
(Joe Seyfried)
2019 年 2 月 9 日午後 2:24
1
Hi all,
I tried to upload a larger patch of emoji into my instance. At first, everything worked fine. Then, I increased the number of files I can upload to 20, and started dropping emoji onto the customize page. I had a few errors here and there, but after an upload of around 120 images, no further upload was possible. Plus, the emoji picker did only show 3.
Deleting all emoji made things worse: now I cannot upload a single emoji, symptoms like this:
Can this be a regression of this ? Or another problem? I even tried rebuilding the whole container to no avail.
zogstrip
(Régis HANOL)
2019 年 2 月 11 日午後 1:47
3
Any chances you could invite me (regis.hanol@discourse.org) as admin on your instance so that I can have a look ?
JSey
(Joe Seyfried)
2019 年 2 月 12 日午後 9:02
4
Sent you that email… Funny, I was able to upload around 60 emoji before it started spitting out error messages again… Any hints would be appreciated.
zogstrip
(Régis HANOL)
2019 年 2 月 13 日午後 9:09
5
Turned out, if you drag & drop 20 emojis at once, you’ll get rate limited by NGINX pretty soon…
I changed it so that we now upload emojis sequentially
https://github.com/discourse/discourse/commit/94fe0af900e9f53091f3a2e4fbc8e11fa8ecc7c4
JSey
(Joe Seyfried)
2019 年 2 月 13 日午後 9:17
6
Great, thanks! I will check this out on the next occasion and let you know!
JSey
(Joe Seyfried)
2019 年 2 月 14 日午前 11:55
7
Hm. Looks better now, I was able to upload most of them in batches of 10-15 each. But now it coughs up the same error. Nginx logs show an error 400:
[14/Feb/2019:11:49:51 +0000] "www.mysite.tld" 46.5.158.250 "POST /admin/customize/emojis.json?client_id=…3a4432c24effb&authenticity_token=…Bgz73aiLveyLUDkslPywsIKzrqb40O7Rul7h1iNAb6HVfjqO7wv1tVSiJnT4nL8wtBtvMvQ%3D%3D HTTP/2.0"
"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_3) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/12.0.3 Safari/605.1.15" "-" 400 229 "https://www.mysite.tld/admin/customize/emojis" - 0.000 "-"
(did not even know that there was an error 400…)
Stephen
(Stephen)
2019 年 2 月 14 日午後 3:40
8
Did you update discourse to pull in the changes? Are you on tests-passed?
JSey
(Joe Seyfried)
2019 年 2 月 14 日午後 5:58
9
Yeah, I’m on tests-passed, missing only todays commits:
zogstrip
(Régis HANOL)
2019 年 6 月 7 日午後 9:09
11
@daniel can you try to reproduce?
zogstrip
(Régis HANOL)
2020 年 5 月 20 日午後 3:11
14
@dan 、この問題を再現できるか試して、もし再現できなくなったらこのトピックをクローズしてください。
dan
(Dan Ungureanu)
2020 年 5 月 29 日午前 11:26
15
問題なく絵文字をアップロードできました。このバグは再現しなくなりました。
