Canvas Theme Template
In the Canvas Theme Template discussion, creator manuel introduces a flexible theme starter kit designed for both new and experienced developers. The template separates styling logic into a main template and a Canvas Settings component, allowing users to customize themes via CSS properties and admin UI settings without forking core components.
The thread covers several key topics:
  • Setup & Configuration: Users jrgong and mk0r clarified that theme settings are located within the Canvas Settings component rather than the main theme settings. manuel provided instructions on adjusting banner outlets and confirmed that editing scss files directly is currently required for deep customization, though a new UI component for style variables has been added to the Canvas Styles component (manuel).
  • Bug Fixes & Adjustments: User pmusaraj reported issues with tag labels appearing in the wrong location and the admin sidebar looking inconsistent. manuel addressed the sidebar harmonization and clarified that banner positioning requires manual configuration in the component settings to avoid forking core components. manuel also fixed a scrolling issue in the solid sidebar.
  • New Examples: manuel shared a new “Central” tribute theme that leverages the template’s components to replicate the original Central theme’s layout.
  • Future Compatibility: User Canapin asked about compatibility with the upcoming “Foundation” update. manuel noted that while some declarations may become obsolete, the theme is generally designed to follow the default Foundation look rather than enforcing specific base styles.
:information_source: Summary Quick start your theme design with a prepared theme template.
:busts_in_silhouette: Audience New developers that want to get started building themes for Discourse. Experienced developers that want to use a ready-made template.
:hammer_and_wrench: Repository Manuel Kostka / Discourse / Canvas / Canvas Theme Template · GitLab
:eyes: Preview Canvas Themes
Canvas provides a flexible template that allows you to create custom themes with less coding. Easily adjust properties and configuration values to tailor a theme to your needs.
Example views
The base template retains default values and remains neutral in design.
Minimal adjustments that modify a few custom properties and define a highlight color:
A design that integrates the Topic Cards component and custom styles for banners:
An elaborate theme that includes a custom font and unique color schemes:
A play on the former Central theme:
Usage
  1. Clone the Theme Template.
  2. Synchronize the theme with your Discourse instance using the discourse_theme gem.
  3. Go to the admin backend and manually adjust these theme component settings:
    Category Banners
    Plugin outlet → above-main-container
    Tag Banners
    Show below site header → uncheck
    Show above main container → check
  4. Edit scss/properties.scss to define values for custom properties
  5. Edit about.json to add assets, color schemes and more theme components
A closer look at the setup
The Canvas Theme template only extends the default theme skeleton with bundling a few theme components and adding some ready-made style files. The actual features are handled by a separate theme component Canvas Settings. This component serves two functions:
This split setup allows you to create a theme using the Canvas template, while still benefiting from ongoing fixes and updates provided through the component.
Example themes
You can preview shared example themes at https://canvas.kostka.studio. There’s a theme toggle at the bottom of the sidebar to change theme.
Review code of the shared example views or install them as your starter theme from these repositories:
:tada: A huge thank you to Discourse for sponsoring the development of this project!
Those theme settings don’t show up when I tried to install the example themes. Is that expected behavior?
The settings are on the theme component installed as Canvas Settings. It’s maybe a bit misleading that settings are always named Theme Settings on the ui, also on theme components.
Found them in Canvas Settings component, thx!
Thanks so much for working on this @manuel.
I took the Editor version for a spin locally, it mostly works very well, but I noticed some small issues.
On a default install, without changing any settings, the tag label in the Extra Banners component shows up in the wrong place:
The category banner is also shown in the same place, above the sidebar. Latest topics, Hot topics are correctly shown in the main column.
I’m guessing it’s not a goal of the theme to fully cover the admin UI, however, the light and dark Editor color palettes have the admin sidebar looking quite different. I am curious if it is possible to harmonize with the non-admin sidebar.
The theme is meant to show banners next to the sidebar, using the above-main-container outlet. The Extra-Banners component uses that outlet by default, but the two components for Category and Tag banners are by default rendered below the header. I wouldn’t want to fork these components, just to set a different default outlet.. That’s why I put these instructions:
But if that’s easy to miss, maybe there’s a better way to put it? :thinking:
Yeah, that’s easy enough and seems a good approach for this theme. I just added a commit!
Ah yes, I see how we got here. We don’t necessarily want to change the defaults in the category/tag banners components, don’t want to fork them either. Tricky to fix, let’s leave it as is for now and see if others run into the same issue.
Admin sidebar change looks good already, thanks!
Could these instructions be elaborated a bit? Is it not possible to just install from the admin UI? Thx :folded_hands:t4:
EDIT: I installed via the admin UI and it seems to be working except there doesn’t seem to be anywhere to edit scss now
EDIT: nevermind, I see that is probably expected and you’re showing to edit the theme files directly. I wonder if it could be on the roadmap for this to happen via the admin ui? Like, have a variables editor same as you have a settings editor
I don’t know what’s on the core roadmap, but one thing you could do right now is create a new theme component right on the admin UI:
And then declare custom properties on it’s CSS file. You could either look up properties on the Readme file. Or copy the contents of properties.scss from the theme repo.
How do I clone this to Gihub? Still a bit on the green side :wink:
You could import it through the UI:
However, if you want to be able to sync changes, I believe you’d need to pull to a local clone and then push from it. Something like this:
  1. Clone from GitLab
git clone "https://gitlab.com/manuelkostka/discourse/canvas/theme.git"
  1. Set push URL to your GitHub repo
git remote set-url --push origin "git@github.com:Username/Reponame.git"
  1. Then you can periodically fetch from GitLab and push to GitHub
git fetch -p origin
git push origin
I don’t see a plus on mobile on GitHub. May need to try the command lines when Home.
All I see in GitHub on dashboard is option to create a new repo but no claim ne option. I am on free account so not sure if that might have something to do with it.
I added a component that lets you define a few style variables and layout options right on the component ui:
It’s limited compared to declaring custom variables on the stylesheet. But it lets you tinker with a few different looks. Curious to hear if that works! :eyes:
I’m playing with it right now and I think it’s nice! Is there a way to reduce the line spacing of the menu - to make it more compact?
Also, I can’t scroll the solid sidebar, is this by mistake?
I just adjusted the CSS styles for the solid sidebar, scrolling should work again!
However, the solid sidebar is just one of the options on the Styles component I mentioned on the post above. If you want to adjust more styles (like spacing the sidebar menu), you’d need to follow the approach explained above in Usage and A closer look at the Setup: Use your own stylesheet with CSS custom properties – in this case that would be -d-sidebar-row-height.
I’ve put together a new example theme based on this template. As the name suggests, this one’s a tribute to the original Central theme! :hugs: :partying_face:
I loved the layout and visual style of Central and I’ve been packaging some of its features into standalone components, like the Custom User Menu and several sidebar blocks.
I realized that with the sidebar and some styles, this template actually gets you a good way towards the original theme’s look and feel.
In any case, I’m not planning to fully re-build the Central theme.. but I might still experiment with a dedicated topic list style down the road. If you’re curious and want to take a look, the theme is also live here, select it using the sidebar theme toggle: https://canvas.kostka.studio
Very nice. Thanks for sharing.
Thanks for sharing this template! The flexibility with components and the clean design make it really easy to customize. Looking forward to trying it out on my own instance.
Welcome to Discourse :discourse: !
With the Foundation update being the new default in the near future, will Canvas theme template be updated to use the same “foundations” (eh), or will it keep the same style it has now, very close to the current (soon old) Foundation theme?
