카테고리 사용자 지정
Hello, I have 7 Categories at the moment on my Website, and each category having topics relevant to that category, At the moment what i can see there is a button on top “categories” and i have to select that to see all categories, Is there any way to make all categories visible like buttons on top instead of clicking categories and then selecting further?
Hi again Ali !
Do you mean adding category links here?
If so, you can check this component : Custom Top Navigation Links
If not so, sorry I misunderstood
Yes, I want to make my Categories Visible as Seprate Buttons, so don’t need any drop down menues
Ok, the best course of action IMO is to use the theme component and add links to your categories
Then you can hide the dropdown menu using css
.combo-box-header.category-drop-header {
    display: none;
ol.category-breadcrumb {
    margin: 0;
First lines hides the dropdown menu, the rest will realign the top links menu
