Categoria mancante in Argomenti suggeriti
This doesn’t seem to be an issue that has been previously reported, so it must be limited to the plugins/theme/settings on the install, but the category is missing on the “Suggested Topics” at the bottom of any posts, and as a result, the data for the Replies/Views/Activity is displaced.
The install is up to date, and the issue is also present in the /latest and /top views.
This has been present for the last two updates. If anyone could offer any advice, it would be appreciated, thanks a lot.
This is a compatibility problem with a custom plugin. Please remove all non official plugins and see if it persists.
3 Mi Piace
Thank you! I visited /safe-mode without non-official plugins, and it displays perfectly. So it must be one of those non official plugins.
When I browse in /safe-mode and disable unofficial plugins, the issue goes away.
So I edited the app.ymk file to disable any unoffical plugins, but after saving the file and ./launcher rebuild app, the issue still persists.
Does this indicate that I need to completely remove the unofficial plugins rather than just disable them via the app.ymk file?
Topic list previews isn’t an official plugin.
2 Mi Piace
Thank you for your help and patience, I assumed that as it was Enabled? “N” that it wouldn’t interfere, but even though it was turned off, it was interfering.
After I removed it from the app.ymk file, it has solved the issue.
Thanks again!
2 Mi Piace
