Category Page Plugin
Change the category page to suit your needs (one option)…
What it does: completely changes the design on this page. (shows the best authors and topics of the week)
https://github.com/Toxuru/discourse-category-home
Languages: English, Russian
Additional fields in category:
  • categorimg - the second image used on the category page
  • categordiscr - short description of the category
Customization
desktop category page style - Categories and Latest Topics
This is a rather non-standard plugin that requires some preliminary actions. You must fill in additional fields in the categories that will be used in this layout.
After a while, I will try to simplify the implementation, which can be used without such actions. Perhaps this code will be useful.
Not for the mobile version!
To install Discourse Plugin - Install plugins on a self-hosted site
Does this really need to be a plugin? Shouldn’t it be a theme component cc @sam @johani?
Smooth and comfortable. Thank you for sharing, it is much appreciated!
Most of the changes can be done in a theme component. The biggest blocker is the excerpts. Those still require a plugin.
The plan is to allow you to opt for excerpts somehow as a theme component.
hi, any chance this becomes a theme in near future? i.e. the possible blocks minus the excerpts.
I will try to make this plugin a theme soon.
does this plugin be made into a theme yet?
Any progress? Seems to change nothing with latest Discourse :confused:
Unfortunately, I will no longer be able to work on this plugin. This is due to my place of residence, the lack of a development environment, a weak laptop only allows you to deal with css, php scripts.
You can clone the repository, or try to make this solution better, easier. I am sure that this is possible.
