Category Sidebar
The discussion revolves around a feature request for the Category Sidebar. pux wants to be able to customize their Latest feed as a user by selecting which subcategories to display on the fly, using check/uncheck tick-boxes on a sidebar. HAWK initially misunderstood the request but later clarified that this feature is not currently available for users. erlend_sh suggested some existing feature requests, but HAWK pointed out that they do not allow user customization. erlend_sh then suggested a feature called “Favorites” that allows users to build a custom topic list, but pux found it a bit restrictive and reiterated their idea of a drop-down menu or sidebar with check/uncheck options for categories, allowing users to quickly switch between custom and all latest topics.
Hello Discourse Team,
I’m a user of this wonderful software on the Manjaro Forum.
If I click on the Latest tab I would love to be able to choose which sub categories are shown on the fly.
Like for example check/uncheck tick-boxes on a sidebar to include/exclude Off Topic and so on.
What do you think?
Hi @pux
You can already suppress categories from the latest list. Check out the category settings.
Edit: Oh, do you mean as a user? Or an admin?
Hello @HAWK and thanks for the quick reply. I mean as a user.
Right. Ignore me then. You can’t currently do that. :slight_smile:
I did hope to make a useful feature request and thought I start here, or is it better doing that directly on Github?
Nope, you’ve done exactly the right thing. I initially misunderstood your request.
I think you’re looking for something along these lines:
Do those solutions allow a user to customise their feed though? I think that’s the basis of this request.
Exactly, @HAWK your first answer was already, what I was looking for.
I don’t know if you have the ability to suppress categories from the latest list on the fly as a site admin, without to go through settings first or mute categories, but that would hopefully better describe what my thought was.
Ah, well if the self-filtering part of it is what’s most important to you then maybe this is what you’re looking for:
This looks interesting and I will have to try it first, before I can say something. Thank You!
But it also looks a bit restrictive to me.
I was thinking about something like a drop-down menu on the Latest list where you can check/uncheck sub categories, or maybe something like that as a sidebar.
If you check or uncheck a category, the Latest list reloads with the new selection.
For example I would like to be able to get a quick overview over some chosen categories which I’m interested in right now, but maybe not tomorrow, but also be able to switch back to all latest topics, by pressing a default button or something like that.
Hope that makes more sense :slight_smile:
