Is there any way to remove subcategories from the hamburger menu
סיכום מבוסס בינה מלאכותית
The discussion revolves around removing subcategories from the hamburger menu in Discourse. Initially, users were confused about how to achieve this, with some suggesting CSS hacks or plugins. jomaxro pointed out a setting, “Show subcategory list instead of topic list when entering a category,” that controls both the hamburger menu and topic list. However, this setting was later removed and replaced with a per-category setting.
After a bug was identified and fixed, users were able to control the display of subcategories in the hamburger menu by editing category settings. cpradio provided the CSS code .category-links .category-link.subcategory { display: none; } to hide subcategories without turning on subcategory listing.
Scot and others were struggling to find the setting, but tshenry provided a step-by-step guide to achieve the desired result. The solution involves navigating to the parent category, editing category settings, and selecting the desired style from the dropdown menu.
in the meta drop down menu next to user avatar, only categories are shown . This keeps the menu clean .
I couldn’t find any option in the setting searching for subcategory, how can I remove subcategories from the menu?
2 לייקים
I guess I’m not understanding what you’re saying. The categories that show in the hamburger menu display all the categories I have permission to. Both parent categories and child categories.
You’re looking for this setting: Show subcategory list instead of topic list when entering a category.
Strangely, as far as I can tell, this controls both the display of subcategories in the hamburger menu, and whether they appear in the topic list - they can’t be controlled independently.
לייק 1
You don’t see this subcategory in the dropdown? https://meta.discourse.org/c/plugin/extras
He is trying to hide them. I think…
Taking Meta as an example, he wants to hide the highlighted items
לייק 1
Thanks for the screenshot! Yes I think he wants to hide them
but its looks like meta is also showing subcategories so we aren’t doing anything special either to show only categories. You will probably have to do some css magic, create a plugin, or create a setting for this and make a pr.
I’m confused, does the site setting I mentioned above not work? It seems to work fine for me…
Enabled:
Disabled:
Edit: Keep in mind, it’s also affecting the following…
Enabled:
Disabled:
3 לייקים
Works on my sandbox (never knew that setting also controlled that list)
@blake, can I infer from your post that separating the hamburger list and the topic list subcategory settings would be pr-welcome?
What feature exactly are you asking for?
A discreet site setting for “hamburger only shows top level categories” ?
3 לייקים
Yes. I’d like to be able to control the hamburger menu independently of the topic list.
3 לייקים
A pr that adds the .subcategory class to the enclosing LI is welcome. Then you can do it with CSS.
A site setting is @codinghorror’s call
5 לייקים
I’ll take a stab at it after work.
לייק 1
For reference, this is the file in question
https://github.com/discourse/discourse/blob/master/app/assets/javascripts/discourse/widgets/hamburger-categories.js.es6
3 לייקים
OK - so I’ve been digging into this for quite some time now. First time working with widgets, so it took me some time to wrap my head around how everything works.
It looks like @neil committed a new feature that changes the way this works about 12 hours before @Pad_Pors’s first post. I believe this commit explains why we’re now seeing subcategories in the Meta hamburger menu. Primarily, the site setting I mentioned above doesn’t exist anymore. Secondly, I believe the commit as it currently stands is broken. Here’s the commit:
https://github.com/discourse/discourse/commit/a702330ccdfa46a3e110f4df852f451975c51d30
The commit appears to remove the site setting in favor of a per-category setting.
Here’s the line that I believe is broken (no idea how to fix it):
https://github.com/discourse/discourse/blob/master/app/assets/javascripts/discourse/widgets/hamburger-menu.js.es6#L123
If I understand correctly, it says that “if the current category has show_subcategory_list enabled and the category has a parent category, return true”, and thus don’t add said category to the list. The problem is only a parent category can have the show_subcategory_list setting enabled, and parent categories can’t have parents, so this will never be true. It should be “if the current category’s parent has show_subcategory_list enabled and …”
I’ve still not figured out how to modify the CSS for subcategories only, but before I continue working I wanted to ensure my understanding of the code is correct, and ensure I’m hacking at working code.
6 לייקים
Probably a bug, @neil will look at it Monday when he is back.
3 לייקים
Yeah that was a bug. Fixed!
5 לייקים
I have upgraded to latest but I can’t fine this setting yet, should I wait more or is this option gone?
  • I can see the hamburger menu of meta is clean again, so I guess there should be a way to activate this now. is there?
It is on each Category. So visit the Category, choose Edit Category, and it should be in one of the tabs.
5 לייקים
I am having a similar difficulty. The hamburger menu is showing ALL my categories (including subcategories). I went in to the categories that have subcategories and selected subcategory list. That changed the category pages, but not the hamburger menu. So I’m not sure what to do.
