Hi,
Is there a way to Modify the default “Top” to “Hot”?
I cannot find this setting in admin panel, maybe I should change the translation file?
Thanks
Fairly certain you want to go to Admin > Customize > Text Content and search for js.filters.top.title
You should be able to change that via the Admin panel customize text tool. Search for js.filters.top.title
Edit: ninja’d!
I just typed “Top” into the Admin > Customize > Text Content and started to guess as to which one of the 2 it was ![]()
Same here. I took a guess and changed one, refreshed the page and saw that nothing changed, and then changed the other one.
