In the discussion “Changing layout with themes”, klemstance asked if it’s possible to significantly change the layout of pages using themes, specifically changing line spacing, removing user badges from topic listings, and widening horizontal space in posts. Johani replied that Discourse’s theme system allows for extensive customization, and provided guides and resources for getting started. According to Johani, all of klemstance’s requested changes can be made with CSS, but cautioned about the potential effects of changing horizontal space on the timeline. klemstance expressed appreciation for the detailed response and plans to explore the possibilities.
Just to avoid wasting time trying something that’s not feasible, is it possible to significantly change the layout of pages using themes? Specifically, we would like to change the linespacing and remove the user badges from the topic listing, and widen the horizontal space used when viewing the actual posts. Is this a simple matter of CSS tweaking, or are we going to collide with things that are more hard coded?
Yes, the Discourse theme system allows you to pretty much customize everything on the client-side, nothing is hardcoded.
We have a couple of guides that can help you get started
and a collection of open source themes and components for you to look at in the Customization > Theme category
As for the specifics in your post
Line spacing can be changed easily with CSS
I’m not sure I understand what you’re referring to, but you can add or remove elements with a theme / component. You can also hide elements with CSS.
This is doable with CSS but you’d need to be aware of the effects your changes might have on the timeline (the scrollbar on the right-side of topics). That said, this is all just CSS and you can make whatever changes you want if you know what you’re doing.
