I’ve searched through every CSS element I could find through the console and I tried my best to change colors and wraps but I cannot find a way to change the color of the tag bullet & icon. Whenever the scroll-down header animation initiates, the tag color goes from visible to hardly visible. Is this even possible to do via CSS?
User nexo is trying to change the color of the tag bullet & icon in the Changing tag bullet color discussion, as it becomes hardly visible during the scroll-down header animation. awesomerobot suggests using the before and after pseudo selectors and provides the CSS code to change the color. However, this solution causes issues with the tag visibility before the scroll-down header. awesomerobot then offers a more specific solution by adding .d-header to the CSS code, which should resolve the issue. nexo appreciates the support and is motivated to learn more about CSS.
You need to look at before and after pseudo selectors too
So in this case you need to add
.discourse-tag.bullet:before {
color: $header_primary;
Right, so you want to be more specific
.d-header {
Wow CSS never fails to impress me with the amount of possibilities. I really appreciate your support @awesomerobot, you continue to motivate me to fully learn CSS ![]()
